Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-26-2013, 09:48 PM   #1
1989 25' Excella
Sticky Surface
It's a great day, just purchased my first AS after 2 years of dreaming, and I have a question. It's a 89 25ft Excella, and the interior ceiling has a sticky or tacky feel to it. Is this a breakdown in the material, or was it cleaned or treated incorrectly? What will remove or clean this tacky finish?
PAL07 is offline   Reply With Quote
Old 09-26-2013, 10:22 PM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
glue
It is the adhesive bleeding through. You can get some simple green or soap and ammonia and scrub it like crazy to get it off. After you have ALL of the sticky residue off go to a hardware store and find some Future Floorwax and wipe it on the walls and ceilings. It will seal it for a couple of years. Makes the ceilings nice and shiny for awhile. You can do a search on here for more info.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 10-06-2013, 07:50 AM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The article is on Andy's site Airstream Interiors for $5.00
It's on my to-do list (but at a low priority).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 10-06-2013, 09:14 AM   #4
Wabbiteer's Avatar
Jupiter , Florida
A nylon brush and hot Spic'n Span (I eventually used a homemade round scrubbing brush chucked into a power drill) brightened & lightened my '73 liners to 'like-new' and rid them of that tacky film, just providing elbow-grease and plenty of terry cloth rags to burnish it dry always using a fresh pick-up rag was required.
Once you see the results of scrubbing it clean the effort and mess is justified, but alas, then the thought of all the hidden spots missing needing the same rehabilitation becomes almost unmanageable!
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 10-06-2013, 10:26 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The sticky stuff is the secondary plasticizer from the PVC laminate on the aluminum. It degrades with time and spews from the vinyl. You need to disolve it and prevent it from reoccurring. There are a lot of cleaners that will work. Ones that contain pine oil, work the easiest. You need to then seal the vinyl with Future or another acrylic floor wax
