I have been getting a very bad smell coming from my battery when I have had my 2015 Bambi Sport hooked up to 110 after a length of time (ie: overnight). The battery also feels really warm. Is it getting hot/smelly as a result of too much charging? Should I use the disconnect switch once the battery shows a full charge? Nothing in my owner's manual addresses this.
2022 Atlas
Homosassa
I would check the acid level and if low add distilled water. I would be concerned that if the trailer sat for a long time before purchase that it could have a bad cell. If those two are okay I would have the converter checked out.
Cooked battery. A result of cheap single stage converter supplied by Airstream. I fixed that issue by going to a pair of 6-volt Trojans and a modern PD three stage converter.
MICHAEL
