Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-27-2015, 01:24 PM   #1
sabegirl's Avatar
1991 25' Excella
Central , Arkansas
Running Lights
I replaced a running light lens recently and it ended up falling off during a trip. I guess the newer ones are a tad smaller than the originals. What's the best way to make sure the next lens doesn't fall off. I was thinking I could put a small dab of clear silicone in each corner. Click image for larger version
Name:	ImageUploadedByAirstream Forums1430162630.232002.jpg
sabegirl is offline   Reply With Quote
Old 04-27-2015, 02:25 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
They're supposed to fit but I too have run into loose lenses.
The best thing to do IMO is use clear silicone in a bead on the top 60% of the lens, where it meets the base. There is a drain hole or slot (or should be) somewhere along the bottom or the bottom part of the side -- don't block it.
Old 04-27-2015, 02:28 PM   #3
sabegirl's Avatar
1991 25' Excella
Central , Arkansas
Great. I was hoping that would work. Thank you!!!
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
