-   -   Running Lights (https://www.airforums.com/forums/f44/running-lights-134316.html)
sabegirl 04-27-2015 02:24 PM
Running Lights
I replaced a running light lens recently and it ended up falling off during a trip. I guess the newer ones are a tad smaller than the originals. What's the best way to make sure the next lens doesn't fall off. I was thinking I could put a small dab of clear silicone in each corner. Attachment 237189
Jammer 04-27-2015 03:25 PM
They're supposed to fit but I too have run into loose lenses.
The best thing to do IMO is use clear silicone in a bead on the top 60% of the lens, where it meets the base. There is a drain hole or slot (or should be) somewhere along the bottom or the bottom part of the side -- don't block it.
sabegirl 04-27-2015 03:28 PM
Great. I was hoping that would work. Thank you!!!
