Old 08-11-2016, 01:17 PM   #1
2015 25' FB Flying Cloud
Sandy , Utah
Odd Rivet
I noticed what I believe to be a popped rivet. I have attached a photo. It is tight in the hole and can't be pushed in or pulled out further. The odd thing is that it is, unlike all of the other ones, all by itself. It is directly over the wall cabinet over the sink in a 2015 25FB. there are no other rivets anywhere near it. All of the others are in series and on wall or ceiling supports. I would like to know if anyone else has this out of place rivet and if you think that it is necessary to replace it even though it is tight.
rocco52 is offline   Reply With Quote
Old 08-11-2016, 01:34 PM   #2
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
If is tight and not fallen out I would leave it alone. If it bothers you maybe give it a light tap with a hammer and reset it.
MICHAEL
Old 08-11-2016, 01:39 PM   #3
A W Warn's Avatar
2000 25' Safari
If it is on a rib or a horizontal support between the ribs, you have two choices - leave it till it shears off, or drill it out and replace it.. My choice would be leave it.
If it is not on a rib there may be no reason for it except to fill a hole left from the build process.
If it is not on a rib, do not hit it with a hammer or you will have a dent.
Alan
Old 08-11-2016, 02:19 PM   #4
Kevin245's Avatar
It looks like the installer failed to seat the head of the shank prior to pulling the mandrel. The issue is that the head of the shank needs to bear against the aluminum skin to provide any real clamping force. Maybe they were not paying attention, or it could be that there is an obstruction that prevented full seating.
Once a pop (blind) rivet mandrel is pulled there is nothing you can really do with the rivet short of drilling it out and replacing it in kind. You can try to tap it in which may seat the head, but that will push the bulb end away from whatever it is bearing against, so I would not go this route.
I would drill it out and install a new rivet.
William C. Swinney
Old 08-11-2016, 03:08 PM   #5
Sandy , Utah
Thanks for the input gentlemen. I will be doing some close inspection tonight. My concern was that it might be helping to hold up some bracing that the cabinets are mounted to. I am not sure how they are secured. I am one of those people that has a hard time leaving well enough alone.
Buck Rivet and Rivet BigGrey General Repair Forum 5 05-26-2012 09:29 AM
Rivet on rivet repair Darkspeed Ribs, Skins & Rivets 2 08-19-2011 04:46 PM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 09:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
