Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-07-2018, 02:29 PM   #1
2018 30' International
Denver , Colorado
Dometic at altitude
Hi Team,
I discovered that my Dometic refrigerator (2018 Sig 30’) does not work at an altitude of 10 to 11,000 feet on propane. I have a nozzle switch out to allow my generator to run at this higher elevation. Is there a way to modify the refrigerator and the hot water heater so they can run at the higher altitude on propane without firing up the gen, while also maintaining their ability to work at sea level.
Thank you,
Chris
RChrisClark is offline   Reply With Quote
High altitude Dometic fridge problems handn Refrigerators 81 06-28-2019 12:03 PM
Norcold fridge and high altitude performance star kitty Refrigerators 4 10-24-2014 08:51 PM
Onan carbureters with altitude adj. about year 2000 DaveFL Mechanics Corner - Engines, Transmission & More... 0 09-19-2011 01:11 PM
Altitude generator adjustment ESCAPE POD Generators & Solar Power 12 10-20-2009 09:52 AM
Water heater wont stay lit at high altitude Airstream25 Water Heaters, Filters & Pumps 2 01-26-2008 06:43 PM
