-   -   Dometic at altitude (https://www.airforums.com/forums/f44/dometic-at-altitude-185355.html)
RChrisClark 08-07-2018 02:29 PM
Dometic at altitude
Hi Team,
I discovered that my Dometic refrigerator (2018 Sig 30) does not work at an altitude of 10 to 11,000 feet on propane. I have a nozzle switch out to allow my generator to run at this higher elevation. Is there a way to modify the refrigerator and the hot water heater so they can run at the higher altitude on propane without firing up the gen, while also maintaining their ability to work at sea level.
Thank you,
Chris
