01-13-2014, 09:57 AM
2009 28' International
Columbia
City Water pressure regulator (location) leak?
Where is this regulator located in a 2009 28' International. We have a leak somewhere and have ruled out everything but this component, but can't find it.
Help!
01-13-2014, 10:12 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
According to the 2009 International Parts Book, the pressure regulator is incorporated into the city water hookup, part #601392-05. It's not a separate part.
01-13-2014, 10:14 AM
1976 Argosy 28
Milton
, Ontario
Sinjin,
It should be just inside the trailer close to where the City Water connector is on the outside.
On my '76 Argosy, it is at the rear under the street side bed.
However, in redoing my plumbing it made more sense to relocate it outside before the fresh water hose. That way it not only protects the plumbing inside the trailer but the hose too!
I used the JABSCO 'Water Pressure Regulator' under their Model Number 44411-0045.
Good Luck!
Chris
01-13-2014, 10:25 AM
Columbia
Thanks guys! Always a quick response on this site!
01-13-2014, 10:36 AM
2012 25' Flying Cloud
Battle Lake
It's all one part of the city water hookup.
Describe your leak. For example does it stop when the hot water heater is off. The reason I ask is this is a common problem of water pressure increasing in the water system by the thermal expansion of the water heating. If there is no air "bubble" in the top of the hot water heater to absorb some of this expansion it maybe forced out of the weakest fitting(s). This is especially true of the newer electric/propane combo units, probably due to a higher water temperature or the faster heating.
Doug and Cheryl
01-13-2014, 02:30 PM
Columbia
Yes, there is no leak when the water heater is off, or if the pressure caused by the heated water swell is relieved. I do not know if this happens when connected to city water. We have been running off the fresh water tank lately. Hmmm... Will this happen if connected to city water?
Another thing to consider is a small expansion tank. Just don't know where I would mount one.
01-13-2014, 02:46 PM
Port Orchard
Help!
How do you know you have a leak? Where is the water dripping From?
Have you looked thoroughly at the connections and valves on the toilet? That is a common place for small leaks.
Have you checked the connection on the outlet of the water pump?
Ken
01-13-2014, 03:46 PM
Columbia
Oh yea there is a leak! The dripping shows up on the street side forward and aft of the wheel well. For the final 'Here is the leak' we used dry toilet paper placed at several locations. And the winner, WET ONE was at the city water inlet connector. I was just able to place the TP there with the help of long arms and a pair of pliers. All other fittings were dry.
01-13-2014, 04:09 PM
Port Orchard
You are confusing me. Are two people with different user IDs posting about the same leak in the same trailer?
Ken
01-13-2014, 04:13 PM
Port Orchard
That's a bummer.
I'm guessing that if you detached the filler fitting on the outside of the trailer, you might find enough slack to pull it out far enough to access the back of it.
Ken
01-13-2014, 05:17 PM
Battle Lake
This WBCCI article from Airstream describes how to restore how to restore the "bubble" in your water heater to take up some of the thermal expansion in the water system.
http://wbcci.org/general-information...-november-2013
Doug and Cheryl
01-13-2014, 05:57 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Thanks Doug. I did not know how to create this air space in the tank. In essence making the water heater tank an accumulator too. It makes sense. Good information.
David
PS Brother in law had good walleye fishing on West over the holidays. I have no idea why anyone would want to ice fish?
01-13-2014, 07:18 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
One of our trailers has a built in regulator, one does not. On both trailers I use an adjustable regulator with a gauge hooked to the park water connection. Many parks in areas where it freezes use underground valves with an outlet and handle above ground. Many times these systems have loads of pressure. I want to protect not only my trailer, but my hose as well.
Works well everywhere for me.
01-13-2014, 08:10 PM
Battle Lake
David, this is a reason why, our granddaughter today in the fish house on West Battle. She's proud of her catch.
Doug and Cheryl
01-13-2014, 09:37 PM
2005 28' Safari S/O
Paradise
I had the same problem and just fixed it. Water dripping around the wheel well when the hot water heater turned on, either connected to city water or running off the tank. It was the city water inlet valve. Replaced it and all is well.
Steve
"THE OLDER I GET, THE BETTER I WAS"
01-13-2014, 10:12 PM
Battle Lake
Water Pressure Acculator
The thermal expansion can put a bit of pressure on the water system. I added a small water pressure accumulator from Camping World ($40?) to give some extra expansion space, and generally smooth the operation of the water system.
You can put it anywhere after the water pump but it must be on a cold water line. I put it under the bath sink with the connections down to allow drainage for winterizing. Took a line off the cold water faucet and hooked to it the accumulator, then bought a new line to run from accumulator to the cold water faucet. Pretty easy addition.
Doug and Cheryl
01-14-2014, 05:27 AM
1986 34' Limited
1975 27' Overlander
Conifer
Nice Waleye
Oh Uh! I changed subjects in this thread! Doug, that is a great picture! Being connected to the same small Minnesota town is fun.
Well, fish live in water, and we are talking about water. There is a connection.
I've learned how to create an air space in my water heater, and I've learned pressure regulators can leak. I am planning on installing a small accumulator as I re-plumb my Trade Wind.
I have benefited from this thread. I hope the OP did too.
David
01-20-2014, 08:38 PM
Columbia
Yes, we did benefit from this thread and everyone's suggestions. Pete reinstated the air bubble as suggested above and the leak stopped. He also bought a new shur flow city water inlet but hasn't had time to install it yet.
Thank you all for your input, sorry it took me so long to reply. We have been on the move since he got the air bubble thing working and are currently at Disney and are leaving for San Diego next week.
Thanks again and Happy Trails
Pat n Pete
01-21-2014, 09:32 AM
1987 32' Excella
Nepean
, Ontario
Here is how I had my accumulator installed.
http://www.vsquare.com/howard/photos.../P1000042s.jpg
The PO had included it in the sale, but it was still in its box. I had it installed at JC and it makes a huge difference, especially when boondocking - no surges.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
04-18-2018, 02:15 PM
2004 28' International CCD
rockwall
Same Problem In 2018
I have the same problem that you described, water leaking at the front and back of the wheel well streetside. I believe it to be the city water inlet that is the culprit. Did you get yours fixed.
