06-10-2013, 09:40 AM
2012 25' Flying Cloud
Battle Lake
Best options/gadgets accessories for your Airstream
The list of options/gadgets/accesories for our Airstreams seem endless. Some work well and some are iffy. Name the top best things you have bought for your Airstream, in order of best, and a one-liner why.
Here's ours:
1) ProPride hitch. It has changed our towing experience to pleasant and effortless no matter what the conditions, and easy weight distribution.
2) Michelin tires/16" Sendel T02 wheels. No more concern when the next GYM tire blowout will be on our trailer, at the worst possible time.
3) Solar power/Lifeline battery option. Most of our travel needs can be done without a generator or hookups.
4) Dyson Hot space heater. For our long-term camping, this heats our trailer evenly and quietly, and keeps the temp at where you select it.
5) Sewer Solution. Quick and clean to use when traveling.
6) Moisture Detection Meter. Probe the subfloor during our quarterly Airstream inspection/maintenance to find inevitable leaks before they cause floor rot.
7) Exterior protection products. CorrosionX to prevent/mitigate corrosion at the exterior cut edges, rivet holes, and accessories, Boeshield T-9 for the underbody steel, Glaze polish for the shell, uv protection for the exterior seals/plastics/window gaskets.
doug k
06-10-2013, 10:24 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Some of ours are the same. Our favorites are:
1. 16" LT tires
2. Hensley Arrow hitch system
3. Sewer Solution
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
06-10-2013, 10:31 AM
2012 25' FB International
Trent Woods
, North Carolina
This is good stuff! I do not have my AS in hand yet, but I have purchased most of that stuff in anticipation. What about WiFi? I do not like the solutions I am seeing from Ranger or JEFA Tech.
Larry
06-10-2013, 11:48 AM
2002 30' Classic
Ocala
What brand moisture detection meter is everyone buying?
06-10-2013, 11:50 AM
Oswego
I am using moisture alarms installed in the AS (permanently) which monitor the most common water intrusion/pooling spots. Has called my attention to leaks twice so far.
-Rich-
06-10-2013, 01:12 PM
1976 Argosy 22
Pasadena
Are the moisture detectors used above the floor or in the belly area?
06-10-2013, 01:39 PM
Oswego
Above. I place them in each of the corners....2 in the rear compartment with "wicking" rags stuffed under the flooring and wedged into the sensor leads. The other two are in the front corners.
The rear ones signaled me when the hole drilled into the shell for the back up camera was not sealed properly and once when the rear compartment door frame needed resealing. Both alarms were well in advance of what I would have ever noticed by accident or inspection. They are quite sensitive.
Here are many examples:
Amazon.com: water alarm
-Rich-
06-16-2013, 08:58 PM
2014 30' FB FC Bunk
Hoover
, Alabama
on my thread that this thread was brought to my attention...someone stated that JC is not accepting any mods on special orders besides stock factory stuff...???
I am looking to potentially buy a new one special order....kind of a bummer if some of these things are better if done by JC
06-16-2013, 09:00 PM
2014 30' FB FC Bunk
Hoover
, Alabama
what is "sewer solution"
Also what is this heater thinga-ma-jiggy?
06-16-2013, 09:12 PM
2014 30' FB FC Bunk
Hoover
, Alabama
600w inverter from factory vs. aftermarket?
600w Inverter $725
06-16-2013, 09:13 PM
Hot Springs Village
, Arkansas
06-16-2013, 09:18 PM
2014 30' FB FC Bunk
Hoover
, Alabama
Originally Posted by daymonjones
Nifty!
06-16-2013, 09:33 PM
Biloxi
, Mississippi
Sewer Solution and Andersen WD system, best 2 buys I have made for my Airstream.
MICHAEL
06-18-2013, 10:52 PM
1978 25' Tradewind
Metro Phoenix
(2) Sets of genuine Don Featherstone pink flamingos
(4) Michelin LT tires
(5) Miniblinds
(6) New cushions for dinette and gaucho, vinyl with heavy duty foam on one side and cloth with memory foam on the other
(1) Zillion LED exterior lights
(24) chrome lug nut covers
06-19-2013, 04:25 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Not gonna follow instructions by putting these in order:
1. Just installed a Drainmaster sewage system...WOW, is this a cool product
2. 16" Michelins LT's and Sendel wheels with a Dill TPMS
3. SS Amana oven/stovetop AND a Cuisinart Microwave/Thermal/Convection oven
4. Iota converter/charger
5. ProPride 3P (This is NUMBER .5 -- ahead of NUMBER 1)
6. Bogart Trimetric
7. Designer curtains/bedspread/valance boxes
8. 4 roll-out units in what was my wardrobe...for food and pots and pans
9. Honda generators (2 each)
10. WiFi ranger
11. Maxx fans
12. Two brand new Lifeline AGM's that arrived today and will be installed tomorrow
13. a 300W solar system that is on order and will soon be on my roof
14. Maxim skylights
15. FLOR carpet squares (you really can take them up and hose them off..don't ask me how I know...)
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
06-19-2013, 07:16 PM
2013 30' Classic
Greenwood
, Mississippi
Where can I get some pink flamingos?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-19-2013, 07:19 PM
2013 30' Classic
Greenwood
, Mississippi
1. MaxxAir cover over Fantastic Fan
2. Tire covers
3. Tongue lock
4. Equal-I-Zer 4 point anti sway hitch
5. Screens over vents in water heater and furnace covers
6. Our name in vinyl graphics
TAC #MS-10
Airforums #70955
06-19-2013, 07:54 PM
Hollis
, New Hampshire
Pink Plastic Lawn Flamingos: GetFlocked.com.
06-19-2013, 09:26 PM
Biloxi
, Mississippi
I was in Lowes the other and noticed that they had flamingos in several sizes.
MICHAEL
06-19-2013, 09:54 PM
2014 30' FB FC Bunk
Hoover
, Alabama
stupid quesiton, but what exactly is a "Microwave/Thermal/Convection oven"?
I take it it would replace a gas oven......not sure what to think about this though...as I never used such?
And what is "bogart trimetric"...
Thanks you all!
