06-22-2013, 08:32 PM
#41
2013 30' Classic
Greenwood
, Mississippi
Originally Posted by drboyd
Them birds ain't got no legs!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-23-2013, 08:49 AM
#42
1987 32' Excella
Nepean
, Ontario
Originally Posted by crabbey1
Where can I pick up one of the Cellular Antennas? I usually use my Sprint phone as a WIFI hotspot and then use my computer. If having an antenna and an amplifier will help boost service, I would love that!
I bought my antenna through Amazon. The manufacturer of the antenna and the booster/amplifier is Wilson. They have a variety of differently configured kits - I go the amplifier with the internal antenna which has a pick-up range of 2 feet; it has the 12-volt power supply and I also bought the plain antenna. I has JC install the antenna, and I put the amplifier under the armrest of the gaucho (wired in 12volts for it there). The pickup is attached with the double-sided tape it came with just under the window ledge where the dining table folds out from the wall. I also wired in a small switch under the window ledge (switch has a red led in it when the power is on) to power the amplifier on and off.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
06-23-2013, 12:25 PM
#43
2010 23' International
Saturna
, British Columbia
I looked up the Sewer solution and I have to ask - innocently!
What's the advantage? As I see it on the web site, if I put the jet pump part onto my black water outlet, when camping I now have to connect/disconnect two hoses and I still have one hose after its work is done, that had sewage run though it....
What am I missing?
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
06-23-2013, 12:43 PM
#44
Alamo Heights
What am I missing?
It seems to me the advantages are small diameter hose that's easy to roll up, and built in tank flushing capability. I also think they are able to dump somewhat up hill and farther away than regular gravity dump can usually deal with.
— David
06-23-2013, 01:25 PM
#45
2012 25' Flying Cloud
Battle Lake
What am I missing?
What you would be missing is the "stinky slinky".
doug k
06-23-2013, 01:31 PM
#46
2012 28' International
New Orleans
, Louisiana
What am I missing?
I just bought and used one my last trip. The advantage is that it cleans the dump hose. You dump and the jet forces the waste down the hose flush the tank and the flush the hose right from the drain connection. I flushed both tanks and flushed the hose. It is less messy, is in a necessity, no. You don't have to have someone fill a tank from the inside. I still carry a slinky but prefer the Sewer Solution.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
06-23-2013, 05:14 PM
#48
2005 30' Land Yacht 30 SL
Castro Valley
Originally Posted by AWCHIEF
Toad, not so. According to camping world and the maker it is supposed cut the water off completly. It is a defect in manufacturing . I called CW this morning and they are going to send another one. I was told they have received no complaints from the latest batch they have sent ouy. Hopefully this one will work as designed.
The CampingWorld description looks like it was lifted directly form the Oxygenics page, and it says: "The new SmartPause valve allows you to pause water flow to a trickle with the push of a button."
Leaving a trickle flowing helps mitigate two possible problems: 1. If it is full off then full water pressure is on the pipes behind the shut-off, pipes and maybe hose that may not be designed for the full pressure, and 2. If your water heater is fired up and "recovering the pressure could actually increase on the hot side and back up into the cold side of the supply. When you turn it on again there could be a short burst of hotter water. The trickle keeps it equalized, and probably is not more than a pint over one shower.
I used the original Oxygenics in my previous house & really liked it; so much that I'm ordering one now for my moho.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
06-23-2013, 06:55 PM
#49
1970 27' Overlander
Kingston
, New York
(1) Zillion LED exterior lights
Do you have any pictures? Love to see what you did with the LED lights.
