Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-05-2018, 12:51 PM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Conroe , Texas
Barker Levelrite HI-Power 3000 Annual Lube
I have a 2015 27FB FC and looking for advice on how to Lube with grease my power jack It seems to be groaning lately - need help please. The 4 page manual doesn’t help much.
Glenn
PSU1981 is offline   Reply With Quote
Old 07-05-2018, 01:29 PM   #2
2015 30' Classic
Saint Augustine , Florida
I had a Barker on my classic so I don't know if you have the same head as mine had, but I took the head cover off ( 4 screws under it) and put some lithium grease on the gears inside. I used a plastic putty knife. Mine died about a month ago. The integrated brake stopped working so when I let off the switch the jack would start to let the coach go down and it was getting impossible to stop it where I wanted it. Hope yours is OK
accordionman is offline   Reply With Quote
Old 07-05-2018, 02:05 PM   #3
PSU1981
PSU1981's Avatar
Conroe , Texas
Thanks - I was thinking of using WD 40 white lithium grease in spray can. Is that similar to what you used?
Old 07-06-2018, 05:04 AM   #4
2015 30' Classic
Any lithium will work just fine. I used a white lithium it from a tube. I believe the WD 40 version is a spray. Application is irrelevant as long as you get it where it belongs.
Old 07-06-2018, 08:28 AM   #5
PSU1981
PSU1981's Avatar
Conroe , Texas
Awesome - thanks!!!
Old 07-06-2018, 06:41 PM   #6
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Glenn
Glenn,
I think there is some good guidance here about lubricating the gears in the head, but the lubricating of the lifting screw mechanism hasn't been addressed. And I have no idea how to do that, so, I'll be watching, too!
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 07-07-2018, 10:16 AM   #7
CruizinDux's Avatar
Washington , Missouri
Here is a cut and paste from the website https://www.barkermfg.com/vip-3000.html
Owner's manual & parts pdf can be downloaded.
MAINTENANCE:
Once a year, the powerhead should be removed and a liberal amount
of grease (preferably a grease with high melting point) applied directly
to the coupling on which the drive pin rests.
DO NOT POUR OIL into top of the jack post.
Once a year, the housing cover should be removed and the gears
inspected for proper lubrication.
Remove 4 screws and tap around edge of housing to free cover.
DO NOT insert screw driver blade! (This may damage mating
surfaces.)
Before replacing cover, clean mating surfaces.
If lubrication is needed, use Mobilith 460 grease or equivalent.
FYI ...re re-sequencing in regards to the auto stop feature Post #50 pdf instructions at bottom.
http://www.airforums.com/forums/f44/where-can-i-buy-a-30-amp-250-v-slow-blow-fuse-151073-4.html
CruizinDux is offline   Reply With Quote
Old 07-08-2018, 04:52 AM   #8
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I'll bite
So, when Barker says "preferably a grease with high melting point", are they thinking white lithium? Wheel bearing? Other??? If containers of grease provide info on the melting point of the contents I've never noticed it. That's ok with me because I wouldn't know whether any given temperature was too high, too low or goldilocks.
GammaDog is offline   Reply With Quote
Old 07-08-2018, 08:49 AM   #9
CruizinDux's Avatar
I hear ya. I was planning on using the (NAPA) marine gear grease that contains lithium that i bought for the hitch. Not sure if that makes it lithium grease or not. High melting point...??? Maybe I'll talk to Napa
Old 07-08-2018, 12:41 PM   #10
PSU1981
PSU1981's Avatar
Conroe , Texas
MAINTENANCE:
surfaces.)
Thanks Bob - especially concerned about how to re-sequence??? When I click on your link - says page is unavailable...
Old 07-08-2018, 12:42 PM   #11
PSU1981
PSU1981's Avatar
Conroe , Texas
Says page not found???
Old 07-08-2018, 01:54 PM   #12
CruizinDux's Avatar
lets try this again.
http://www.airforums.com/forums/f44/...-151073-4.html
if not search for cruizindux re-sequencing, which is what I did.
thx for the heads up.
b
[edit../bingo]
b
Old 07-08-2018, 05:07 PM   #13
CruizinDux's Avatar
PSU1981, got your thx and you're selcome. Any experience comments from your re-sequencing process would be appreciated. Never can tell when it might come in handy...especially since i'll have the head off for lube.
Happy trails
Old 07-09-2018, 01:42 PM   #14
PSU1981
PSU1981's Avatar
Conroe , Texas
Happy trails
Bob,
Well can’t find the manual tool - so ordered another one. So project on hold for now.
Old 07-09-2018, 04:55 PM   #15
CruizinDux's Avatar
Are you referring to the emergency handcrank? the jack is the same size as the male end of a 3/8" drive. I keep a 7 /16 12 point deep socket & 6" extension just uncase. Socket size varies by the # of points if the socket.
B
Old 03-06-2019, 06:16 AM   #16
2015 23' FB Flying Cloud
plymouth , MA
going back to removing the power head to lubricate the gears. the top cover is just an inspection cover and you cant see the gears , so do you remove the scews at the bottom of the power head ? and does the head just lift off ? I did read one time about installing the head to make sure you have full travel of the lift. I am concerned about removing the power head and running into a problem once its off. Has anyone actually taken the head off , lubricated the gears and replaced the head ?
Gibbs is offline   Reply With Quote
Old 06-05-2019, 12:47 PM   #17
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
My jack (barker 3000) quit going down a couple of days ago when I returned from a trip,so I of course I looked at my manual and this thread and decided that it was probably the switch,(which I have ordered) I also noticed that I was supposed to be lubing the head every year which I did not do.(2014 unit) So, thought I may as well do both at the same time.
I seem to be running into a problem with totally removing the top of the head after I remove the 4 screws. I can move it up to the point where I can see inside,but, no further. There is a c shaped retainer clip on the top which stops the small gear from riding up. Is that supposed to be removed? I have read all the instructions I can find and nothing mentions this clip. I don't want to break anything. Anyone else have any problems,and how did you solve it? Thanks
gandttimes is offline   Reply With Quote
Old 07-07-2019, 07:08 PM   #18
CruizinDux's Avatar
Gandttimes, did you ever get this question answered?
Old 07-08-2019, 12:10 AM   #19
Sag Harbor , New York
Similar to Bob, I am also wondering how this worked out? We have the same jack and want to do the maintenance, but came across the same apparent limitation. Other Barker 3000 owners seem to have had their jack replaced etc., in this 2015 thread:
http://www.airforums.com/forums/f457...er-139798.html
Did you remove that retainer clip and lift off the top cover, in order to inspect and lube the gears?
Peter
Old 07-08-2019, 12:15 AM   #20
Welcome to the forum. Your post count is still at "1" so I am wondering what you did about lubricating the gears. See the last few posts for details.
Peter
30 amp fuse size for LEVELRITE High Power 3000 PSU1981 Hitches, Couplers & Balls 8 10-01-2017 08:30 PM
Levelrite HI-Power 3000 -- Do I need to Grease this? PSU1981 Exterior Restoration Forum 0 09-02-2016 11:48 AM
Heavy-Duty Levelrite Hi-Power 3000 Barker Manf. Dwellstream Hitches, Couplers & Balls 8 08-24-2016 06:53 AM
LevelRite High Power 3000 Smoked! Mikem1961 Jacks, Stabilizers, Lifting and Leveling 0 07-21-2016 07:05 PM
Levelrite 3000 issue IanPoulin Jacks, Stabilizers, Lifting and Leveling 4 07-22-2014 09:15 AM
