Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-30-2008, 11:45 AM   #1
1975 25' Tradewind
Sammamish , Washington
Airstream Repair Shops in Western WA
Hi-
I have a 1975 Tradewind that need some minor work. A/C needs to be charged, Fridge is having trouble running on propane. Seals in holding tanks need to be replaced.
Can anyone recommend a good repair shop in Western WA for these issues? I called the dealership and they didn't want to do most of the work since it is an older model.
Thanks!
nalesueur is offline   Reply With Quote
Old 09-30-2008, 12:34 PM   #2
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
No offense, but none of the items mentioned sound minor: they have "replace" written
all over them for a coach of that age. Sorry, I have no info as to a good mechanic on
your side of the pond. When we're up here, we use Eric's R.V. in Sequim, not sure they
do trailers, though. 800.488.3697. Good luck.
Mike Leary is offline   Reply With Quote
Old 09-30-2008, 05:19 PM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I've had good luck with Evergreen RV in Lynnwood ("evergreenrv.com")
Marc
Old 09-30-2008, 05:27 PM   #4
Originally Posted by nalesueur View Post
Hi-
Thanks!
Keep in mind that when you use a non Airstream dealer, they cannot buy parts from Airstream and must go through a dealer. That usually means the parts will cost you more money.
Or, they could substitute generic parts, which takes that repair out of the Airstream family.
Ask for a ball park estimate, before work is started, always helps.
Many owners on this site can tell you if thats an "ok" price.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-30-2008, 05:43 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi-
Thanks!
Most of the issues sound pretty straight forward. DO NOT let them talk you into replacing the A/C unit. If you still have the original BayBreeze it is built like a tank and can be repaired and recharged...unlike the newer throwaway units. I have mine done by a guy that specializes in commercial refrigeration units.
Aaron
WBCCI #XXXX AIR #2495
Old 09-30-2008, 06:06 PM   #6
Mike Leary's Avatar
Ajo , Arizona
Even tanks need to be upgraded.
Old 09-30-2008, 06:20 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
No doubt. However I was told by a local RV dealer that my Bay Breeze unit was "bad" and needed a $700 replacement unit. In reality all it needed was a $35 capacitor. That $665 will a long ways towards replacing things that really need to be replaced...like plumbing, converter, axles, tires, shocks and the like. If you don't know how to fix something and are an uniformed consumer you will end up spending money on things that aren't really necessary. There are very few repairable products available anymore, the Bay Breeze fortunately is one of them. As are Airstreams, I have been messing with RV's and repairs for quite some time and have yet to find too many units that can take the outright abuse that some Airstreams do and still be functional. Too many repair people are untrained and their answer to anything they don't understand is to either refuse to work on it because it is too old and they don't make parts for those anymore, or replace something because they don't know how to fix it and refuse to admit to their limitations and the fact they are ignorant of that particular product.
Aaron
Airstream Repair Shops??? xtrm69 Our Community 4 06-29-2022 01:02 PM
Repair shops woodssd General Repair Forum 26 10-26-2008 03:57 PM
Seattle Repair shops ? Dan S All Argosy Trailers 1 04-01-2007 02:42 PM
Local repair shops wotocho Commercial Listings 0 01-21-2007 06:44 PM
Repair Shops CBBOB General Motorhome Topics 1 08-12-2002 08:26 PM
