Old 10-10-2007, 04:35 AM   #21
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Originally Posted by RIstream'n
OK you P3 users is there alot of adjustments and manual activation needed???
Brian
no. the installation/user manual has very small pages with big type
seriously, setup is a snap...
what i'm finding out is, make sure the TT system is setup with your controller...
boondockdad is offline   Reply With Quote
Old 10-10-2007, 05:31 AM   #22
RIstream'n's Avatar
2008 27' Safari FB SE
Cumberland , RI
Will do. Thanks
RIstream'n is offline   Reply With Quote
Old 10-17-2007, 08:56 PM   #23
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
For those using the Tekonsha did you also install a Pulse Preventer. Apparently it's needed to prevent the use of the four way flashers from activating the brakes.
Old 10-17-2007, 09:21 PM   #24
"Cloudsplitter"
Wink Hazzard Flashers
Up until recently, have always used Tekonsha, but cannot recall whether
the 4ways activated the brakes, but then again I can't remember ever using
the 4ways while moving.
How would the sob's know which way your turning.......lol
ROBERT CROSS is online now   Reply With Quote
Old 10-17-2007, 09:34 PM   #25
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here is some info. on installing it.
http://www.tekonsha.com/tebcpulseprev.html
Old 10-18-2007, 04:52 AM   #26
RIstream'n's Avatar
Cumberland , RI
Ordered the P3 yesterday. I'll let you all know what I think of it......
Brian
Old 11-28-2007, 07:26 AM   #27
2007 25' Classic
marco island , Florida
the prodigy will not work well with the new elec/hydraulic brakes...per airstream and MY experience....only the p3 or the hayes genesis.
vpurdy is offline   Reply With Quote
Old 11-28-2007, 09:14 AM   #28
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
I had the opposite experience. My Prodigy worked well 04 F-250 with my Actibrake system in the 06 Classic. My Integreated tow command in my 06 F-250 is even better!
Michelle TAC MT-0
Sarah, Snowball
Old 11-29-2007, 06:04 AM   #29
2007 25' Classic
exact same problems with the prodigy....problem is depending on who you talk to...actibrake or tacomsah...or airstream....last year everyone was saying that the actibrake folks had adjusted their actuator to handle the prodigy...ergo...i insatlled the prodigy...disaster! i called prodigy yesterday and inquired about the new P3...was told they have a fairly good success since it was introduced in may this year....stick with the hayes genesis...it works is the bottom line.
Old 11-29-2007, 06:08 AM   #30
2007 25' Classic
michelle...be aware...the prodigy will go out at some point if you have elec/hydraulic brakes...and when it does it's expensive because it toasts the actuator which is non-repairable...must be replaced...and it will also blow the charging circuit in your tow vehicle...to say nothing of the rotors damage, caliper damage and pads....you never even knbow it's cutting on and applying brake pressure while traveling...but it cuts on and off for a second or two continulously and you never realize it until it's too late.
Old 11-29-2007, 08:25 AM   #31
Huh?
Is this personal experience. Was the gain too high? I had the boost set to 1 and the gain was about 3.0. Damage to pads calipers and actuator? How and what kind? Turning it on and off? That sounds like a possible break away switch circuit problem. Was it properly synced?
I now have th tow command in my new truck and use it. I like it and it works well with the actibrake.
Michelle TAC MT-0
Sarah, Snowball
Old 11-30-2007, 09:40 AM   #32
ScottW's Avatar
Hernando , Mississippi
I sent email to active technology and got the following:
Scott,
I have attached a copy of our latest approved brake controller list for your review. The Prodigy brake controller IS on the list and it should work just fine for you. The Prodigy brake controller is "designed" for use with electric brakes BUT it is such a popular brake controller, we had to design our system to work with it.
Please let me know if you have any more questions.
Thanks;
Mike Adamietz
Product Manager
Active Technology
515-965-9105
Here is the attachment I rec'd
Approved brake controllers for use with Active Technology’s ActiBrake as of June 14, 2007:
Tekonsha Prodigy / Drawtite Intella-Stop Ultra (same as Prodigy)
Hayes Genesis (need to program for electric/hydraulic)
Tekonsha P-3 (need to program for electric/hydraulic)
Tekonsha Primus / Drawtite Intella-Stop Digital (same as Primus)
2006, 2007, 2008 Ford Integrated brake controller (does not work properly with all 2005 models)
Hayes Energize XPC
Hayes Endeavor
Hayes Energize III
Hensley Tru-Control
DOES NOT WORK WITH TEKONSHA VOYAGER OR DRAWTITE INTELLA-STOP (same as Voyager) or any brake controller that has a LED light to indicate brake activation!!!
Use of time-based brake controllers is not endorsed by Active Technology.
If you have any questions about brake controllers or have a controller you do not see on this list, please call Active Technology at 515-285-0195 BEFORE using it with the ActiBrake electric/hydraulic brake system.
I haven't contacted Tekonsha yet. FWIW.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 11-30-2007, 09:29 PM   #33
ScottW's Avatar
Contacted Tekonsha, but don't really expect an answer. If I get one, I'll let you know.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 12-03-2007, 09:39 PM   #34
ScottW's Avatar
Got an email from Tekonsha: They write.....
"Good Afternoon Scott;
Thank you for choosing Tekonsha for your towing needs.
The Prodigy was designed fro use with electric braking systems only. The only controller we have that is recommended for the electric over hydraulic brakes is the new P-3.
If there is anything more that I can help you with, please let me know.
Have a good day !!
Charlene Clark
Technical Support Representative
Cequent Electrical Products
101 Spires Parkway
Tekonsha, MI. 49092
888-785-5832"
FWIW...Think I'll buy the new P-3!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 12-04-2007, 07:24 AM   #35
2007 27' Classic FB
Havelock , North Carolina
I found it thes videos on the ActiBrake website that dicusses the Prodigy controller http://www.activetech1.com/videos/7-icabctr.mov
Or a list of install movies Active Tachnology-Installation Video
I have a 2007 27FB classic with the Prodigy installed when we bought it so I am real interested in this thread even though I haven't had any problems.
Phil
nsteel is offline   Reply With Quote
Old 12-04-2007, 07:43 AM   #36
ScottW's Avatar
Phil,
Thanks. I'd forgotten about that video clip. I've still got the CD that came with the Prodigy. Sounds like a simple "sync" each hook-up will satisfy the situation. I've always done that anyway. I know Michelle has, as she mentioned it months ago. She's had no problems, nor have I.
Are we in agreement? Keep the Prodigy and keep on 'syncing'?
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 12-04-2007, 07:57 AM   #37
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
ACK! Head just exploded. Confused
OK, I have a 2006 Safari 25' FB SE.... I just installed the Prodigy Sunday!!!! Now I ask... uh do the Classics have electric-hydraulic and the Safari's just have electric or do I need to get another brake controller and start over?
The burn from the soldering iron is just starting to heal....
Paula
Old 12-04-2007, 08:18 AM   #38
ScottW's Avatar
Paula,
the 2006 Safari's have electric brakes. I pulled one with the prodigy for a year...no problems. I am pulling an 07 Classic with the same Prodigy, synced each hook-up and have had no problems. Looking at the 'evidence' above, the Prodigy will work with either, although it was designed for electrics only, (your trailer), but will work with elec/hydraulic if synced properly at hookup (per active tech).
Confused?
tow what ya got, with what ya got. Sounds like no problem.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 12-04-2007, 09:13 AM   #39
Sync Sync Sync
Prodigy will work fine with both. You will need to to sync with the Classic. Set the boost to what ever is correct by the instructions. Then manually active the prodigy fully and run the gain all the way up and down. THis tell the Actibrake the maximum signal to expect. Otherwise it will put full brakes on all the time. I had this problem after the factory disconnected batteries for welding on my frame.
Soldering iron? did you solder you connections? Why not use something safer like a crimper and but conectors?
Michelle TAC MT-0
Sarah, Snowball
Newbie question rebel beck Hitches, Couplers & Balls 3 10-29-2005 06:32 PM
Newbie question Old Nick All Argosy Trailers 5 05-17-2005 06:21 AM
NewBie Question Chitown AirStreamers 1960 - 1965 Safari 9 05-13-2003 08:27 AM
Brake Controller Question Rickk48 Brakes & Brake Controllers 3 03-17-2003 03:30 PM
Newbie question Rog0525 Our Community 2 05-27-2002 01:30 PM
