this string of posts at least SUGGESTS the kodiak disc can provide a LOT of use...
OR that i failed to BRAKE much in 55,000 miles of towing...
so HOW or WHY can some users report LESS than 10k or even 5k of duty before NEW pads are needed...
while these pads look to be good for ANOTHER 50,000 miles easy...???
i had gathered so MANY reports from reliable service shops AND owners about POOR pad life that it was important for me 2 sort OUT this issue...
and i did last year, after several exchanges with kodiak and their suppliers...
_____________
here's the short version...
kodiak is primarily an aftermarket supplier of disc brake upgrade kits...
1. and MOST of those go to BOATING trailers owners (as diy) or marine shops doing UPgrades on boating trailers...
the a/s market and use came later.
kodiak has supplied kits with ORGANIC, semi-metallic and ceramic pads.
the CERAMICS go primarily to BOATING use because they perform BETTER with water exposure (less/no rust)
and those boat trailer kits OFTEN have stainless lines or rotors too...
and because BOATers tend to tow SHORTER distances...
so the ceramics THEY use (at the request of MARINE users) last many seasons (without rust) but don't go MUCH distance.
2. shortly after a/s started using the K- brakes on the ASSEMBLY line, kodiak
began shipping SEMI metallic pads with those OEM installs.
THAT is WHAT MY TRAILER GOT WHEN BUILT IN march of 05...
some early kits had organic, but MOST of the factory ASSEMBLY LINE installs were with SEMI METALLIC pads.
THE SEMI METALLIC PADS wear LONGER than the ceramics...
but do produce some RUST on both the pads and rotor faces (from ferrous fibers imbedded)...
3. the dealers/service shops and DIY folks can REQUEST either pad material...
but MANY/most of the KITS go out with ceramics pads if NOT specified,
OR because the service shop/secondary vendor, or customer thinks the ceramics are BETTER,
but they are NOT better, except in WET/low use applications...
4. so when i SPECIFICALLY mentioned the high mileage on my set...
the kodiak rep said
"YOU GOT THE SEMI METALLIC PADS",
and
"if you want the same performance in the NEXT set buy semi metallic replacements..."
so the replacements purchased were also semi metallic, direct fit, oem spec and size.
____________
so the puzzle was solved, at least 2 my satisfaction.
this report is NOT ABOUT ALL brand or versions of ceramic pads...
there are several companies MAKING pads and DOZENS of brand labels STAMPED on those pads...
but it IS my understanding of how and WHY kodiak supplies WHAT they supply...
____________
and i sure am happy with the 1st AND 2nd set of SEMI METALLIC pads in THIS application.
cheers
2air'
