Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 04-19-2018, 09:07 AM   #1
steverino's Avatar
2018 30' Classic
Ivins , Utah
Drum Brake inspection on Nevr-Lube axles
I talked to a local shop (not Airstream) about doing a brake inspection and to track down a squeak on one of the axles on my 2010 27FB, with Nevr-lube Dexter axles and drum brakes. I was surprised when he said that, because of the Nevr-Lube hubs, he needs a special tool and drain the grease out of the hub in order to remove the drum. Although I had not done it myself, I thought that once the wheel is removed, the drum just pulls off.
Sounds odd that a no-maintenance bearing needs to be disassembled in order to do routine periodic maintenance on the brakes. Needless to say, I walked, and am now doing some more research, and probably just do it myself. Are there any special tools or procedures needed to remove the drums?
steverino is offline   Reply With Quote
Old 04-19-2018, 09:18 AM   #2
steverino's Avatar
2018 30' Classic
Ivins , Utah
Well, well, well, it looks like the drums don't just slide off.....
http://www.airforums.com/forums/f465...le-119933.html
Old 04-19-2018, 09:26 AM   #3
dznf0g's Avatar
Oswego , Illinois
They have a retaining nut, like any other hub, but there is no "special tool and drain the grease out of the hub in order to remove the drum". Just a large socket/wrench, snap ring pliers and it slides off the spindle. It is pressed into the drum (or disc) hub, but you don't press out unless you need to replace the bearing. The grease is sealed in the bearing set and has no "draining" nor repacking provision.
-Rich-
Dexter Never-R-Lube Inspection and Maintenance Ted S. Wheels, Hubs & Bearings 25 03-25-2024 03:54 PM
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 14 02-21-2022 07:55 AM
Dexter Never Lube axles boomerang1 Axles 1 07-21-2012 07:59 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 04:35 PM
Nevr-Dull polish? Deluxe21 Cleaning, Stripping & Polishing 8 06-30-2010 10:28 PM
