Old 02-04-2003, 08:33 AM   #41
Tire ratings
Charles.
Goodyear Marathon load range "D" tires have a load carrying capacity of 2540 pounds at 65 psi tire pressure.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-04-2003, 12:16 PM   #42
Chas's Avatar
Images: 22
Yes, I knew the Marathons are rated for more weight but would rather be setting as high as I could and wanted to retain the original look as well. I doubt I will ever even come close to the max weights anyhow. I usually pay more attention to the letter rating of the tire, actual numbered weights seem to be pretty much subjective anyways.
Chas
Chas is offline   Reply With Quote
Old 02-04-2003, 02:08 PM   #43
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Exclamation Just for info
Chas, I found this link on another RV site. You might take comfort in reading it~ It speaks volume~!~ http://www.rv.net/forums/index.cfm/f...Yes/page/1.cfm
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 08-10-2003, 06:08 PM   #44
Retired.
. , At Large
More on Tires
I have a set of Michelin XCA 7.00R15 tires on my unit, load range C, max inflation 60psi. Does anybody know if these are still made? They seem like a very good tire, and radial to boot.
(in Florida)
Old 08-11-2003, 08:59 AM   #45
1972 27' Overlander
Saline , Michigan
I have a 72 27' International with Goodyear Marithon radials
ST 225 /75 R15 Load range C.
On the door side of the trailer the wheels rubbed the inside of the wheel well. It looked like the wheel well was bulged out so I screwed and pop rivited it back, then patched the wheel well.
I just did a complete brake job and new wheel bearings and now look to have about 3/4" space.
I like the Goodyear tires but prob need a more narrow tire.
Any suggestions.?
Steve
loechli is offline   Reply With Quote
Old 08-11-2003, 09:49 AM   #46
Steve.
Check the tire to wheel well clearance on each side of the trailer.
A quirk in the production process may have happened in your case. If the dimensions are not equal, then please let me know, and I will guide you accordingly, to determine why.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-19-2003, 09:32 AM   #47
Have just picked up 1987 Sovereign 25'. Has new Carlilse St225/75D15 radials. Anyone had experience with these?
George Jr.
George Jr. is offline   Reply With Quote
LT versus ST tires on a trailer 91Excella Tires 18 08-29-2014 04:03 PM
Trailer Tires? Austin Runner Tires 21 06-27-2004 11:42 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
Trailer Tires? Dave&Heide Tires 14 02-16-2003 06:01 AM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
