Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 02-27-2019, 08:48 AM   #1
Buickman's Avatar
1974 Argosy 26
Athens , Georgia
TPMS and Ceramic Beads
Just bought a set of Goodyear Endurance for the Argosy. The local Treadit where I bought new rims and the tires does not offer balancing service. Upon leaving, the first tire store I stopped at "said" they didn't have lead weights that would fit the new rims. I suspect that was BS as I didn't buy the tires from him. Anyway, so I am considering using Dyna Beads ceramic beads in lieu of lead. http://www.innovativebalancing.com/index.php I will also be using the TST 507 pressure monitors. So my question to anyone who has used this set up is, I plan to use the valve stems with filters on them that come with the beads, has anyone had a problem with the TPMS using ceramic beads?
Buickman is offline   Reply With Quote
Old 02-27-2019, 12:32 PM   #2
2013 28' Flying Cloud
Penn Yan , New York
Balancing
I installed new Endurance tires last year.
The tire store told you BS. On aluminum rims you use stick on weights. Amazing how many tire shops have inexperienced people. I have run into some.
Take your wheels and tires to a reputable tire store.
They will put the weights in the center of the wheel on the back.
I have the same 507 monitors and they are great.
Good luck.
delrossa is offline   Reply With Quote
Old 02-27-2019, 01:57 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I have run Dyna beads for over 10 years in my moho tires with TPMS with no problems.
Cheers, Dan
~ Margaret Thatcher ~
Old 02-27-2019, 04:04 PM   #4
Buickman's Avatar
1974 Argosy 26
Athens , Georgia
Thanks delrossa, Smartstream. Since I had not unloaded them from the bed of my truck I took them to another tire shop and they balanced them with no problem for $20.
Old 02-27-2019, 04:46 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
It is OBE now, but I think with the screw-on TPMS transmitters you should use steel stems. IIRC there have been multiple posts on here of rubber stem failure with screw on TPMS.
Al
Old 02-27-2019, 04:57 PM   #6
Buickman's Avatar
1974 Argosy 26
Athens , Georgia
I did get the metal valve stems. Partly for the TPMS and also to hopefully help keep the hub caps from creeping or if the do to minimize damage to the stem.
Old 02-28-2019, 01:35 PM   #7
1985 31' Excella
st. Paul , mn
I use these on everything , semi-truck , pickup truck trailers .
I was in the auto repair bis. for 40+ yrs. and seen lots of things , and anything that changes / loose when you dismount tire is a waste .
Centermaitics you keep and put on the next truck , trailer , lots of reasons , I consider nothing else .
https://mrtrailer.com/centramatic.htm
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 03-01-2019, 07:38 AM   #8
UncleBad's Avatar
2018 27' Tommy Bahama
Marana , Arizona
Ditto. Centramatics on AS and TV.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Plastic beads for clearcoat removal? john hd Cleaning, Stripping & Polishing 23 10-21-2011 11:25 AM
Wheel balancing beads nickcrowhurst Tires 27 06-07-2010 07:24 AM
Dyna Beads wheel balance LI Pets Wheels, Hubs & Bearings 3 11-19-2006 09:48 PM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 10:42 AM
