Originally Posted by slowmover
WD once tensioned adds weight to TV front axle and TT axles at a 2:1 ratio.
I guess what this means is that the tongue weight, for example, 1000 lbs would be split about 660 lbs to steer wheels and 330 lbs to TT wheels, correct? However, what I want to achieve with my auxiliary tank full is about 4500 lbs steer and 4600 lbs drive axles of TV. This will be adjusted via the number of links of tension on my Reese sway control/WD hitch, along with air springs on drive axle.
As fuel is used, the weight F/R should become more equal as the tank is slightly rear of center.
All of this will be given its road test as I am headed out for about 2500 miles in a couple days, will try to get weights with near full tanks, then after about 600 miles with 320 lbs of fuel burned off.
I may share my results, unless I am so embarrassed I have to make something up....,.LOL Oh my ....still LOL
Ms. Tommie Lauer
