03-28-2005, 08:44 AM
#21
1954 22' Safari
Deerfield
Originally Posted by Jim & Susan
Lou and Craig,
I think you and I had the same, horrifying thought. I was afraid this thread was going in a whole different direction that was not going to be pretty. Especially when I read:
“Rusty nuts….to help get them off….”
Yeah, between the rusty nuts and Pahaska's navel jelly, it really sounds like something your doctor should have a look at.
03-28-2005, 11:48 AM
#22
Sounds bad.
Maybe they will need to operate!
03-28-2005, 12:12 PM
#23
Retired.
, At Large
Driving the bus even further. and heading for a cliff...
So, Tim, have you gotten your trailer's nuts off yet? Did you have to use a splitter, or the navel jelly?
03-28-2005, 01:55 PM
#24
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
I have everything on order. The new shocks are coming and I ordered the Aerokroil from kanolabs.com.
I'm not going to attempt the replacement until after the NorCal Rally on 4/8.
03-28-2005, 02:52 PM
#25
Tim,
Where did you order the shocks from?
03-28-2005, 03:08 PM
#26
1960 28' Ambassador
Northern
Oasis RV at www.oasisrv.com. They were about $34 each.
Originally Posted by pattersontoo
Tim,
03-28-2005, 03:11 PM
#27
1960 28' Ambassador
Northern
Odd.....
The Aerokroil folks called me up before filling my order and wanted to know what I was doing with their product
I told them I was removing some rusty nuts on a shock mount and he wrote it down and said that was ok.
Said they had a California forumlation that he could send me Which probably means it's not as good as the regular stuff.
So, if I wasn't removing rusty nuts with the kroil, what else would I be doing with it?
03-28-2005, 03:18 PM
#28
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Man that is wierd! Don't drink it!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
03-28-2005, 03:24 PM
#29
Aluminut
2004 25' Safari
I've had some luck with WD-40. I pre-treat the whole thing the night before and again the day of. So far so good. I think most of what's been covered would work better, but if you have some WD-40 handy, you could try that first before going out and buying some "stuff".
03-28-2005, 03:49 PM
#30
1960 28' Ambassador
Northern
Your probably right. I just want all my ducks in a row before I started the project.
The can is only $8.50 so if it works as good as they say, it would be worth it.
But I didn't know I couldn't drink it before I ordered it
I think I'll spray some on my cat first to see how he reacts
03-28-2005, 04:01 PM
#31
Use it to scent your plastic worms?
03-29-2005, 05:37 AM
#32
Retired.
, At Large
Umm, you can try something I really like, called Howe's oil. As far as I know, it is available online, a half gallon is around $25.00, and should last you for years. I use it on all sticky or rusted parts (and I get a lot of them).
My breakage rate using this stuff is around 10%, versus around 40% using most other penetrating oils. Oh, and it has a pleasant scent, so maybe you could also use it as a deodorizer...
Oh, yeah, here is their website:
http://www.howeslube.com/site/
You can get a spray can from your local Truck stop, if you don't want the giant ecenomy size.
