Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 11-03-2013, 07:03 PM   #1
billnovus1
1961 16' Bambi
Salinas , California
Need to replace my '61 Bambi's axle
What they charging if I may ask. Need to replace my 61 Bambi's (broke a spindle yesterday) and not really looking forward to doing it myself. thanks, bill
novus1 is offline   Reply With Quote
Old 11-03-2013, 07:18 PM   #2
Most likely, your axle is welded in place.
Therefore a good welding shop is the place to have the work done.
Typically, to replace a single axle that was welded in place, takes no more than 3 hours.
Your axle can be upgraded to newer standards, by someone that knows how, and at no additional cost.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-04-2013, 11:06 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Andy is correct, your axle is welded in place, however when we install replacements in this era of trailer, we always fab mounting plates like later Airstream's have, then bolt the new axle in place. This makes things much simpler to replace in future if the new axle ends up bent due to a road mishap. If you have welding capability, you can do this at home. If not, you're better off finding a good welding/fab shop to do the work.
Colin
Colin H is offline   Reply With Quote
1980 Excella curve in axle? mikem74 1980 Excella II 2 07-22-2015 12:13 PM
1969 Ambassador Axle Replacement Silverflames Axles 13 03-04-2012 07:28 AM
14" to 15" on single axle???? tinbender Wheels, Hubs & Bearings 3 01-16-2012 07:49 AM
