Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Prev Previous Post   Next Post Next
Old 10-05-2009, 06:55 AM   #1
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
It Pays to Check....
I pulled a PM on a used trailer I up picked recently. The first hub was pulled and the bearings removed. The outer looked pretty good, but the inner was a bit of a surprize.
It looks like a PO had driven the inner bearing with a punch to get the bearing seal out and damaged the roller cage. The scary part is that they simply re-installed it.
The cage was deformed enough that it came in to contact with the race as evident by the shiny spot.
Picking up a new set and grease seals today.
Don't overlook your wheel bearings.
Regards,
Kevin
ID:	88240   Click image for larger version
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Kevin245 is online now   Reply With Quote
Check this out! cosmotini Off Topic Forum 2 09-03-2009 11:14 AM
Check This Out.. davidh Off Topic Forum 6 03-04-2006 01:37 PM
Who Pays? fastrob Our Community 5 08-20-2005 06:03 PM
Check this out... Sneakinup On The Road... 5 10-26-2003 09:22 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
