Old 07-20-2009, 10:03 AM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Bearing slip
It is clear that the inner race of both bearings move on the spindle at some point in time. My question is when and why?
This clearly can not happen on a pressed on bearing but why does it happen on a slip on bearing? You would think the load on te race would hold it in place.
2004 Excursion 4x4
Old 07-20-2009, 10:34 AM   #2
"Cloudsplitter"
The bearing race is pressed on the spindle and should not spin.
If the wheel bearings have been re-packed and the bearings re-installed on the wrong race that COULD cause your problem. Bearings should ALWAYS be re-installed on the race they came off of.
To be safe dis-assemble and re-pack one at a time...old school.
Old 07-20-2009, 10:37 AM   #3
1988 32' Excella
West Palm Beach , Florida
Question
I've owned three trailers and had the same happen on all at one time or another. It's a good question?
2dogtraveler is offline   Reply With Quote
Old 07-20-2009, 10:49 AM   #4
1988 32' Excella
Are we talk apples and oranges? The race is pressed into the hub and is not moving. It's the inner part of the bearing moving on the spindle.
Old 07-20-2009, 11:27 AM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
"That would be the inner race"
ArtStream is offline   Reply With Quote
Old 07-20-2009, 11:42 AM   #6
"Cloudsplitter"
Yep inner...my oversight.
But assembly is the same, match bearing and race.
Old 07-20-2009, 01:00 PM   #7
HowieE's Avatar
Images: 12
Let me clear things up a bit.
The INNER RACE of a slip on bearing is what I am referring to and yes they do turn on the spindle. My question is why?
As noted above with a pressed on bearing on shaft this would not happen.
2004 Excursion 4x4
Old 07-20-2009, 01:49 PM   #8
"Cloudsplitter"
Howie,
I am not familiar with a press on inner bearing. How would you install the inner seal?
Both races are pressed into the hub. The inner bearing should slide snugly over the greased spindle, it is kept from turning by the bearing preload. The spindle should be replaced if scored badly, or the bearing is too loose. If an inner bearing overheats it can get "welded" on the spindle and will pull apart when the wheel is removed.
Old 07-20-2009, 02:21 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
If the bearings are pressed on, the the preload of the bearings would have to be adjusted with either a crush spacer or shims. With the slip fit the preload can be set with the retainer nut and then cotter keyed.
Kip
Old 07-20-2009, 02:45 PM   #10
HowieE's Avatar
Images: 12
There are 2 type of roller bearing. Those that press on a shaft and the bearing in turn are pressed into a frame, both races are fixed and slip on bearing like those used on trailer axles, only the outer race is constrained.
With a slip on bearing the inner race is free to turn on the spindle. There is evidence that the inner race does turn on the spindle at some time. My question is under what circumstances does the inner race move? I have always greased the spindle when install the bearing. Even being greased one would think the preload would keep the inner race from moving against the spindle but that is not the case.
If you look at the inner side of the thrust washer you will see a polished ring indicating the race has turned against the washer. Like wise if you look at the underside of the spindle at both the inner and outer bearing you will see evidence the inner race has moved against the spindle.
2004 Excursion 4x4
Old 07-20-2009, 03:50 PM   #11
"Cloudsplitter"
Ok.... I think we have a failure to communicate...
bearing cup=race
http://k0swi.microlnk.com/2BUYRIGHT/...20DIAGRAMS.htm
Old 07-20-2009, 06:10 PM   #12
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Could it not be that an inner race just has a tendency to slowly creep on the spindle due to drag of the rollers as they roll around at at high speeds?
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-20-2009, 07:11 PM   #13
HowieE's Avatar
Images: 12
Brian
That's the best explanation I have heard yet, but the markings seam to be more that a slow creep would produce. There was heat present because of discoloration on the bottom of the spindle and inside the inner race. Not enough to warrant replacing the bearing but enough to cause someone with terminal tinkeritise to ask a question.
2004 Excursion 4x4
Old 07-20-2009, 08:19 PM   #14
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You should not be preloading the bearings. The specification is to have them with 0.001 to 0.005 inch end play. That translates to just a feel of just the tiniest motion if you rock the wheel perpendicular to the axle. That means you bring them up snug by hand and back them off to the next notch. The inter races are fairly snug (0.002 - 0.005 loose) but should be able to turn. There should be no heat build up because they do not turn that fast and there should be less that 150F temperature build up due to friction at high speeds on the road from supporting the trailer. Discoloring does not occur below 400F. Blue color does not develop until over 600F. If you have any discoloring you have done something wrong and way over tightened the bearing.
Old 07-20-2009, 08:44 PM   #15
"Cloudsplitter"
Say what?.....http://www.pirate4x4.com/tech/billav...20pre-load.pdf
Old 07-20-2009, 09:29 PM   #16
Mexray's Avatar
1978 28' Ambassador
Morada , California
I think it's important we're all on the same page here...
Tapered roller bearings - the kind in our trailer wheel hubs - consist of:
1. Tapered roller bearing assembly - cone shaped - called by mechanics, the CONE.
2.. Bearing cup - to accept the CONE assembly - called the CUP.
The CUPs are intended to have a press fit into their part of the assembly - the wheel hub - are aren't meant to move once installed.
The CONEs are intended to slide onto the axle shaft with a close tolerance, and are held in place with the outer wheel bearing pre-load by the nut/washer, etc.
We all know this stuff - let's just get on the same page and call em' CUPs and CONEs...to avoid confusion...
I believe most spinning CUP problems occur due to wear causing the CONEs becoming loose to the point of overheating and distorting the CUPs enough to loosen up, also lack of lube and improper adjustment are probably the chief culprits...
As some have mentioned before...once the CUP becomes loose, it's time to replace the wheel HUB/DRUM! It's just not cost effective to try and fix em' - they're too cheap!
Ray & Pat; Morada, CA
Old 07-21-2009, 05:34 AM   #17
"Cloudsplitter"
Thank You....'ya hit the rivet right on the head.
Old 07-27-2009, 05:17 AM   #18
1977 31' Sovereign
1989 34' Excella
Spinning cups are a no no. Slight rotational movement of the cones on the shafts is unusual but not a problem. There should no color developed on any bearing surfaces. Most tapered roller bearing fail due to improper maintenance. This includes: contamination, improper mixtures of greases, over or under tightening or adjusting the preload, lack of grease, and fatigue life of the bearing materials. Airstream does not recommend preloading the bearings that come on your trailer. In an idea situation some minor preloading can be beneficial but the in the field experience has been that many more failures have occurred due to people not properly controlling the preload and over torquing the bearing, resulting in early failures. Therefore, Airstream has not recommended preloading the bearings. Here is a helpful how to from the Nevada unit.
Maintaining your RV- Wheel Bearing Maintenance
Slimp Dolly JimGolden Hitches, Couplers & Balls 13 06-21-2009 02:38 PM
Limited slip axle - must have? cbgenrich Tow Vehicles 88 03-07-2009 07:26 AM
Bearing scare wingfoot321 Axles 10 10-25-2007 08:57 PM
Slip Fitting On Top Of Black Tank To Toilet Radman Sinks, Showers & Toilets 3 05-02-2007 03:11 PM
replace bearing? michaelsessa Axles 5 04-27-2007 12:54 PM
