Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-15-2016, 04:29 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Axle replacement on 1980 Caravelle/Argosy
I am working on finding a source of a new axle for my 20 foot Caravelle. I believe it is the same size as a Argosy Minuet 6m. I would rather not drill or enlarge holes or weld on the shock arms. I have talked to Colin and we are comparing information on this axle. If anyone has replaced their axle on a Caravelle or Minuet 6m I would appreciate any information such as outside frame measurement,, start angle degree, etc etc. Thanks, Don
glacierrunne is offline   Reply With Quote
Old 07-15-2016, 08:01 PM   #2
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Collin took care of everything for me. You will most likely have to cut out the axle fits into a little bigger. If I was to replace mine again I would do 32 degree angle. If yours grey tank is like mine it is kind of low in the back.
thehandyman is offline   Reply With Quote
Old 07-16-2016, 09:40 AM   #3
1980 20' Caravelle
Handyman, do you have the measurement you gave Colin for outside of the frame? thanks, Don
Old 07-16-2016, 03:28 PM   #4
1980 24' Caravelle
No I don't think I had to give him any he had just finished another redo on a 24 foot caravella including axles. So he had the measurement already if I remember right.
Will try and look up any email I sent to see.
Old 07-20-2016, 06:25 PM   #5
1980 20' Caravelle
Handyman, can you e-mail me at glacierrunner1@hotmail.com. Colin is looking in his files but can not find the info on the axles. If I could get some more info from you it would help me and Colin to figure out the correct measurements. Thanks for your time! Don
Old 07-22-2016, 02:54 PM   #6
1980 24' Caravelle
Did you get my email?
Old 07-25-2016, 10:24 AM   #7
1980 20' Caravelle
Handyman, no e-mail--try sending private one in forum or resend to glacierrunner1@hotmail.com thanks, Don
Old 12-23-2016, 02:08 PM   #8
1980 20' Caravelle
replaced Axle
Thanks to all who responded to this thread. I ordered the axle from Colin and only had to enlarge a hole in the shock plate for a perfect fit. Trailer tows better then before- I also went down to 550lb torsion bars. I hope I Never have to replace the axle again!! Don
Old 12-23-2016, 07:30 PM   #9
1980 24' Caravelle
Cool
Old 02-03-2017, 12:28 PM   #10
1980 20' Caravelle
Bellingham , Washington
Smile 1980 caravelle
We have a 1980 caravelle. New to Forum today. My wife and I replaced our axle from Inland RV in 2006. Had a hard time ordering because they thought our trailer didn't exist at that time. It is exactly the same fit as the Argosy 20ft Minuet because that is what we ordered after giving the measurements to them. We jacked it up and were able to replace exactly with the new axle. (included brakes and shocks) Was wonderful because it raised the trailer up a little and has been great since. Owned it 17 years now and have been on some long trips to Colorado, Minnesota, California etc.
jwkiefer is offline   Reply With Quote
Old 02-14-2017, 07:56 PM   #11
1980 20' Caravelle
Stoughton , Wisconsin
We just replaced ours using a Dexter axle ordered from a local Dexter dealer. I ended up having a trailer shop do the work for me and it cost just under $1,000 for everything - including removing the shock mounting brackets from the old axle and welding them onto the new one. Colin had quoted me $650 for just the axle, so to me it was worth the extra $300 to have someone else install it.
We just purchased ours in September and are looking forward to breaking her in this Summer!
80Caravelle is offline   Reply With Quote
caravel
Do all Caravelle's have the name Caravelle on them? Atlee 1980 Caravelle 6 11-26-2011 08:14 AM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
Trailer height for 1980 Caravelle? Whisperwoman1 1980 Caravelle 2 11-27-2002 08:06 PM
