Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 09-02-2015, 05:23 PM   #1
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
Window Air Conditioner installation
Greetings, I am leaning towards installing an A/C unit through the rear window
in my 65 Globetrotter. I have seen some pictures from others who have done this. My question is in regards to the wiring. As the shower occupies the the center area, it seems obvious that I would not want a hot 110 outlet in that area.I don't think I can be diligent in shutting off a breaker. If the unit is hard wired I would not be able to remove it when on the road or when not needed. It seems to me that this is the best location to avoid the direct blast in sleeping and work areas. I plan to have a desk/eating counter on the curb side below thse windows and cutting a new hole will adversly affect storage. I would appreciate any comments or suggestions. Thanks, Jim
JLGT5107 is offline   Reply With Quote
Old 09-02-2015, 06:06 PM   #2
1981 31' Excella II
New Market , Alabama
Are you wanting to do this because you don't want to pay for a roof unit? The purists on here won't like that idea. You can also go with a split unit that does not have the roof box.
You might also consider the ones that just have an in and out hose that sits on the floor.
Perry
Old 09-02-2015, 06:10 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Cut a hole? No, thanks. I would buy a roof top unit.
CRH is offline   Reply With Quote
Old 09-02-2015, 06:32 PM   #4
rideair's Avatar
Best and fastest way would be to just hang the plug that comes off the AC unit to the outside, use another extension cord to it for the electrical box and you're done.
I've done this more than once.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 09-03-2015, 05:18 PM   #5
JLGT5107's Avatar
Although expense is a consideration, it is more about the looks of the unit on the roof and wondering about the actual use of the unit. I live in the north east
and if my primary use of the trailer is here it is not as important as in other parts of the country. However, as I think about it, the time it takes to set up at each stop might become ponderous. The trailer is gutted now so cutting hole in roof and running electric and drain would be simple. What is a split unit? Also i am planning on using a CAT heater so is an A/C with heating coil of any benifit?
Thanks for your input. Jim
Old 09-03-2015, 05:36 PM   #6
mandolindave's Avatar
reinventing the wheel
There are reasons why manufacturers don't use window air conditioners, and CAT heaters.
mandolindave is offline   Reply With Quote
Old 09-03-2015, 05:44 PM   #7
Mission , Texas
The down sides of a window AC is holding it in place and whether or not it will survive bouncing around.
The down side of CAT heat is CO, keeping enough ventilation going so you don't die.
I'd go rooftop AC and a forced air furnace.
nrgtrakr is offline   Reply With Quote
Old 09-03-2015, 06:18 PM   #8
JLGT5107's Avatar
Death is inevitable, but I would prefer to get as many years of airstream use as I will have put into airstream restoration. Thanks for your advice, Jim
Old 09-03-2015, 06:52 PM   #9
reinergirl's Avatar
Hollis , New Hampshire
Here's some ideas for a removable front window A/C. If you put an awning shade on the window no one would even know it's there!
http://www.airforums.com/forums/f427...tml#post426245
Off-Grid COOLING & AIR CONDITIONING | Livin' Lightly
reinergirl is offline   Reply With Quote
Old 09-04-2015, 09:56 AM   #10
1981 31' Excella II
A mini split system has most of the guts outside say on the tongue of the trailer and the blower inside. Personally, I think you are better off with a roof unit. Someone on here has done the split unit with the air handler in the front under the bed or something. You can get a low profile roof unit if you want it to blend in better.
How to Install a Mini-Split Air Conditioner | Video | This Old House
Perry
Old 09-04-2015, 10:46 AM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Agree - and the best part of this idea is that you plug it in to the post and it doesn't blow breakers if you're using an induction burner or a curling iron while the A/C is running. On a bigger unit like a 30' or 33' you don't need 2 roof units and 50 amp service. For someone in the NE, the only time they'd need an A/C at all is when camping in a commercial cement slab campground in July. In some place like Penn Woods or most state campgrounds you're in the shade and pretty comfortable with just a fan or two going.
A really small unit 8000 BTU or less is only slightly bigger than a milk crate and can be left at home in the garage during the spring and fall.
Paula
Old 09-04-2015, 04:30 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
We have been using a window unit In our 66 for three years. I got the idea from another owner here. It sits on a small wooden snack table that has its front legs resting on the propane tanks. The back legs are cut off and the support sits over the front window ledge. It plugs into the nearby outlet. I fashioned a surround out of heavy clear vinyl and it gets velcroed to the wall around the front window.
Works very well, except when it's 95 out and the trailer is in the sun. I will see if I can find a photo. The unit cost me 35 bucks and rides in the Expedition when traveling.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-04-2015, 04:34 PM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Only photo I could find..sorry its not more helpful?.rideair in the link above has the same set up
AIR #005
retired!
Old 09-04-2015, 05:52 PM   #14
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Check with Colin Hyde about his personal AS that has a window A/C installed on the curb side of his vintage AS
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 09-18-2015, 11:12 PM   #15
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Window AC
65 GT Man
I designed a window mount for my 66 TW and it works great. Mostly it rides in the bottom of the wardrobe closet. It only takes 10 minutes to install. I could not wait to get that ugly wart off the top of my Airstream.
For photos and lots of details I have a thread dated June 1, 2012 titled 5000 btu/hr AC powered by a 1,000 watt Genny.
I hope this helps.
Dan
Old 09-20-2015, 10:08 PM   #16
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Here are some photos of my window installation of a 5,000 btu/hr AC unit. As you can see, it only takes up about 1/3 of the window, so you can still see out and let natural light in. It is located in the middle bedroom/closet area of the Tradewind. Therefore, if you close off the front area and the rear bathroom, I don't care how hot it gets, the ac will cool this small 40 sq ft section, in the event a small child needs to take a nap in the middle of the day. Part of the key to the design is that the ac unit is mounted on the window frame at the cg (center of gravity) of the ac unit. Therefore no external support is needed.
90% of the time we don't need AC and the unit rides in the bottom of a cabinet.
If you want more information, tap on Touringdan, tap on statistics to find the threads I have started. Then tap on the 5,000 btu/hr AC powered by a 1,000 watt Genny thread.
Dan
ID:	248596   Click image for larger version
ID:	248598   Click image for larger version
Replacing Air Conditioner with Roof Window justgoclimb Windows, Doors, Locks & Vents 13 08-15-2015 10:54 AM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
window air conditioner in cabinet? Smoky Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-04-2009 04:10 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
