Blockage in the air flow would be constant unless the spider is moving around.
I have seen is a loose orifice cause this, and it was on a newer unit.
Another area I would consider, since you rig is newer, is if you do not have many miles on it I would look at the possibility of oil getting to the burner. This could be from the gas valve manufacturing or the gas line.
2004 Excursion 4x4
