Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 02-22-2018, 08:24 AM   #1
1969 31' Sovereign
McCall , Idaho
Suburban NT30A furnace replacement
I have a 1969 31' Sovereign Airstream. I am getting ready to replace the Suburban NT30A Furnace with a modern unit. It looks like the Suburban NT30SP is the logical choice. Is the installation relatively simple, turnkey, any mod or extensive changes, difficulties?
Eric Pedersen
McCall, Idaho
supercubep is offline   Reply With Quote
Old 03-02-2018, 10:53 PM   #2
Elk Rapids , Michigan
Interested to hear what you find out....
matthewsx is offline   Reply With Quote
Old 03-03-2018, 05:13 AM   #3
1988 Argosy 32
Lomita , California
take it out then have a rv shop speck a new one, new thermastat may be needed
Wolfe is offline   Reply With Quote
Old 03-13-2018, 09:40 PM   #4
1972 31' Sovereign
Walnut Creek , California
It's not a big deal. If it's the same situation that my 72 Sovereign was it's almost a direct swap to the NT30SP. I had to add a 1/4" spacer to the bottom to get it to line up with the vent hole. A new exterior vent will come with it and is just slightly different diameter than the original. You'll need to use it. Other than that just follow the instructions for wiring. Your old two wire thermostat will work fine with it.
noangel is offline   Reply With Quote
Old 03-13-2018, 09:41 PM   #5
1972 31' Sovereign
Easy Peasy!
Replacement for a Suburban NT30-K furnace? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 16 04-25-2015 08:09 AM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 23 11-28-2011 05:28 PM
Exact replacement for Suburban NT30MA furnace for 1979 31' Airstream wacnstac Stoves, Ovens & Microwaves 4 10-25-2006 10:02 AM
Replacement thermostat for Suburban furnace SafeHarbor Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-09-2005 10:14 PM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
