Old 05-28-2010, 06:43 PM   #1
Homestead , Florida
replacing armstrong TR21-12
I have a 72 Globetrotter with the origional Armstrong 21-12 A/C unit that I am getting rid of. It has a new fan motor but the compressor is shot and there is a hole in the capillary tube. Everything else seems to work fine, I just have a free Coleman that I want to use in it's place. Anyone interested in buying, trading, parts, please let me know.
patkelly is offline   Reply With Quote
Old 05-28-2010, 09:39 PM   #2
Bentonville , Arkansas
I have a 1964 Overland with a bad fan motor/selonoid. I wonder if these two share the same motor. I have been so busy on the interior, that I have not get the scaffolding set up for me to check the model on the AC.
If all holds true this weekend I will get up there and look the motor over.
Ginder75
Ginder75 is offline   Reply With Quote
Old 05-28-2010, 09:59 PM   #3
Ginder75
The original 64 AC was Armstrong model TAC110.
Most of the parts are very different between those 2 models.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-29-2010, 09:23 PM   #4
Thank you for the information. I spent most of the day working on my trailer, I have so much to do, learn, and fix. But when I am done, it will be mine.
Ginder75
Old 06-04-2010, 08:22 PM   #5
fuselage's Avatar
Thermostat
do you have the thermostat and are you willing to part with it?
fuselage is offline   Reply With Quote
Old 06-05-2010, 06:13 AM   #6
Homestead , Florida
I don't think it is the origional thermostat, it is a honeywell, spring type that mounts on the side of the overhead storage locker. If you think it might work, I will find out what model it is.
Old 06-09-2010, 11:32 PM   #7
fuselage's Avatar
Thermostat
Can you possiably post a photo, and is it golden in color, mine was also the spring type, commonly used with that model Armstrong A/C.
Armstrong TR21-12 Help Please? Gael79 Furnaces, Heaters, Fireplaces & Air Conditioning 39 06-28-2016 05:16 PM
FREE: Armstrong TR21-12, w/ext. shroud, 4parts? Maryw164 Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2010 10:52 PM
Armstrong TR21-12 gonna fixey ??? pansy Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-08-2008 07:08 AM
Schematic wiring diagram for Armstrong AC TR21-12, GO7series DMC Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2007 12:01 PM
Hello, looking for a schematic of the wiring in my Armstrong AC model TR21-12, DMC Member Introductions 1 07-10-2007 06:11 AM
