02-28-2018, 07:41 AM
2012 25' Flying Cloud
Berlin
, Maryland
Plumber’s Snake
Has anyone used a plumbers snake to clean the AC drain.
02-28-2018, 07:43 AM
Mantua
, Ohio
No i would plungr it to death first!
02-28-2018, 07:56 AM
1974 Argosy 26
Morrill
, Nebraska
Use compressed air. Not to exceed 30psi.
02-28-2018, 05:35 PM
1999 30' Excella 1000
small town
, Maryland
Maybe use a electricians fishing tool to pull wires. Alot smaller and be gentle.
02-28-2018, 05:50 PM
Biloxi
, Mississippi
I have a small hand pump/syphon. I use that, gives enough pressure to do the/job but not enough to do and damage.
https://www.lowes.com/pd/Arnold-Siph...SABEgKazvD_BwE
MICHAEL
02-28-2018, 06:17 PM
1995 25' Excella
xxxxx
, xxxxxx
.105 weedeater line. Take hose off pan or cup inside trailer. Push line up from outside. Tie a knot in end when it comes out in trailer. Pull back down from outside.
You can heat knot with a lighter to get it just the right size and make it hold it's shape.
03-01-2018, 07:31 AM
Berlin
, Maryland
Thank you for the tips I have run a wire up the tube from the bottom and also used my compressor to clear it. It is draining however I am still getting a drip in side the AS. Is there anything else I can do other then snake from inside the AS
03-01-2018, 07:59 AM
2004 25' Classic
Prescott
Your pan might be cracked right at the drain connection. Some have had this problem. Fixed with JB Welders.
Julia & Bob
W/ Deedee & Boo
AIR #30685
03-01-2018, 10:41 AM
1995 25' Excella
xxxxx
, xxxxxx
x2.... You have a crack....I had one. I fixed it with JB Water Weld putty.
03-01-2018, 06:19 PM
Berlin
, Maryland
Am I correct in assuming the pan is on the roof if I will need to check when back home
03-01-2018, 07:22 PM
1995 25' Excella
xxxxx
, xxxxxx
The pan is what your AC sits in on the roof. You may get lucky and be able to take out your filters and see the crack to epoxy it.
03-02-2018, 07:26 AM
2004 25' Classic
Prescott
It is in the ceiling unit. Best to take the cover off to see if there is a crack. Drain tube should be on the driver's side.
Julia & Bob
W/ Deedee & Boo
AIR #30685
