Old 11-15-2008, 10:46 PM   #1
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
NT24MP Starting??
My NT24MP has a view hole, and a sensor or sparker of some kind on the left, and on the right, a black button that makes clicks down below, and a reset button, and a button that makes loud clicks above that.
What the heack are all these things for??? No instructions.
78GussyTX is offline   Reply With Quote
Old 11-15-2008, 11:06 PM   #2
1973 31' Excella 500
Morristown , Tennessee
I believe this is helpful. I do not have any pictures but you could refer to your unit and hopefully get the idea.
Operating Instructions NT-16, NT-22 and NT-32
1. To light the furnace, turn the manual valve to "off"position and wait 5 minutes. Set the thermostat at it's lowest setting. Open manual valve. Correct operating characteristics depend on this valve being positioned fully open. Never attempt to operate with valve partially closed.
2. Remove lighter hole cover. (On all models, the furnace front is not exposed, so the lighter hole must be reached by first opening the cabinet and then lifting the furnace access door. After lifting access door, remove lighter hole cover.)
3. Press reset button and hold. Insert a burning match through opening so that the flame is near the pilot. On the initial lighting the pilot may not light immediately due to air in the gas line. If such is the case, it may necessary to hold the reset button in for a minute or more before the pilot lights. When the pilot is burning, continue to hold the reset button in for approximately 30 seconds or until the pilot continues to burn when the reset button is released.
4. Replace the lighter hole cover.
5. Replace furnace panels.
6. Set thermostat at desired position.
There is much more on the sequence of normal operation, the fan switch and how it will operate even after the thermostat is satisfied to cool the unit before it shuts down. There is also an extensive section on pilot outage problems depending on which phase is associated with pilot outage: off phase, start-up phase or operating phase.
Hope this helps but if not, I'll be following this thread with interest.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 11-16-2008, 09:33 AM   #3
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
Joe thank you VERY much, yes that helped get the furnace running. Apparently the furnace is not original, it is different from the one explained in the manual.
However, I am still wondering, what is the black circle that makes clicks on bottom right, and the push push button that make louds clicks on top right? Seems like top one might be some kind of flint lighter, sounds like it, but it is on opposite side of pilot light. Weird!
Regards,
Steve
Just Starting To Look SnowGypsy Full-Timing 4 02-12-2008 12:42 PM
Suburban NT24mp furnace troubles Silver Threads Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-24-2007 07:32 AM
Just Starting rick zigler Member Introductions 12 12-29-2006 06:08 AM
Starting over? propstrike Airstream Motorhome Forums 29 08-06-2006 06:14 PM
Just starting to look! Fogducker Our Community 4 01-25-2004 11:52 AM
