Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-27-2010, 12:25 AM   #1
1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
is this an original airstream heater?
and kerosene? picture is of a 53 FC. vent pipe is not pictured but vent hole is there. you can see the filler cap at the top and some kind of fuel filter at the bottom.
greenrig is offline   Reply With Quote
Old 03-27-2010, 04:31 AM   #2
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Its an original Airstream heater.
Originally Posted by greenrig View Post
Is this an original airstream heater? ... and kerosene? picture is of a 53 FC. vent pipe is not pictured but vent hole is there. you can see the filler cap at the top and some kind of fuel filter at the bottom.
Yes, its the "Byam Burner". Here's a restored one in the 1949 19' Trailwind on the opening page:
49Trailwind
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-27-2010, 10:36 PM   #3
1959 18' "Footer"
thank you, this is inspiring. looks very cool with the flame in the little window and nicely restored. i'll have to give it a once over to see if i can get it going.
Old 04-02-2010, 07:56 PM   #4
1959 18' "Footer"
Understanding the byam burner
i need some help understanding this heater. seems like there should be a wick but there isnt. so the fuel (kero/heating oil?) is gravity fed into a filter, then into a dial control which seems to control the amount of oil dropping into the burner. but the burning chamber has no wick? or is mine missing parts? dont tell me the oil just burns in the bottom of the barrel!
Old 04-02-2010, 09:08 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe they're called "pot" burners. The dial control should be attached to a float which regulates the height of the pool of oil. My house had one once, in the 1950s and 1960s, made by the Junger Co. Called "Junger burners" by the local farmers, they were sought after in that era as an improvement over coal and wood heat.
I have seen some in operation in farm houses as recently as four years ago.
Old 04-02-2010, 11:29 PM   #6
1959 18' "Footer"
i guess its not missing parts then. just a burning pool of oil. very simple concept. amazing to me.
what oil would you use in this heater?
to start, would you just throw a match down in the pool of oil?
and climate control seems a bit crude huh?
Old 04-12-2010, 07:53 PM   #7
1959 18' "Footer"
would like to bring this question to surface about type of fuel for this heater. after asking around, seems like 'heating oil' is pretty much kerosene which also burns like diesel. i'd like to use 'lamp oil' but not sure about any of these. anyone with any 'byam burner' experience? thanks
Original Stainless Steel Bowen water heater door adonh Water Heaters, Filters & Pumps 0 02-11-2008 10:29 AM
original '77 Bowen water heater trouble... JohnGalt48 Water Heaters, Filters & Pumps 8 06-14-2007 11:45 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Original Airstream Keychain? overlander76 General Interior Topics 6 04-27-2004 05:22 PM
Original '82 Airstream manual evan Airstream Motorhome Forums 0 03-12-2003 12:56 PM
