Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Prev Previous Post   Next Post Next
Old 10-07-2009, 03:04 AM   #1
Profile:  2002 28' Classic
Alpine , Texas
heat pump & furnace problem
On our 2002 28 ft. classic, when it rains the a/c will not come on, or if furnace is on it will not shut off. if it rains hard enough, it leaks out bottom ot unit. I run it in a/c mode with fan on high and eventually compressor will kick on and work fine. I have tightened bolts holding unit on roof, and do not believe it is leaking there, but not impossible. Resetting electronic thermostatic control will not solve problem, only a drying out session works. Obviously what ever is happening the thermostat thinks i want it hot!!! Thanks for any thoughts. By the way, it is a dometic heat pump.
al66pine is offline   Reply With Quote
Heat Pump Problem Rugger Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-20-2009 08:47 PM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 37 07-16-2009 10:08 PM
Adding A/C & Heat Pump mouth012006 Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-19-2009 06:33 PM
Trouble shooting Furnace/Heat Pump/Air C? Kistler Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-07-2007 01:13 AM
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 04:10 PM
