Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-13-2009, 08:38 AM   #1
Profile:  1976 Argosy 26
G.H. , Michigan
Furnace won't blow hot with 12V lights on.
I have a weird problem with my 76 Argosy. If I turn my overhead lights (any of them) on when the furnace is running the fan slows down and it starts to blow cold. If I turn the lights off the furnace works great.
Any ideas?
sbroemer is offline   Reply With Quote
Old 10-13-2009, 08:50 AM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
The furnace fan slowing down when you turn on a 12 volt lamp is probably an indicator of a bad coach battery or a problem with the converter. I would first try taking another 12 volt battery (like from another vehicle) and see if you have the same problem.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 10-13-2009, 08:54 AM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
The fan needs to operate fast enough to activate the sail switch. Your battery is getting low.
Richard
Charter Member Four Corners Unit
Old 10-13-2009, 10:57 AM   #4
memgrove2000's Avatar
Profile:  1972 31' Sovereign
Elkhart , Indiana
Dust balls or fur balls from a PO's pet may be stuck on the sail switch. With the decreased fan speed it may not be making good contact. Try using an air compressor to blow the furnace clean. It worked for our 72.
Mike
Have a great day!
1972, 31 Foot Sov. Intl.
memgrove2000 is offline   Reply With Quote
Old 10-13-2009, 08:51 AM   #5
Minno's Avatar
Lexington , Minnesota
Are you plugged into shore power, or running off batteries? Sounds like a low battery condition.
And wecome to the forums! Is G.H. Grand Haven by any chance?
Chris
Old 10-13-2009, 09:03 AM   #6
kennethowens's Avatar
Profile:  1975 Argosy 24
Malakoff , Texas
Look for loose connections BEHIND the fuses in the
converter before ya get another battery. I found
loose connections causing problems...dimming/flicker.
The converter takes alot of vibration. Turn everything on
and wiggle the fuses....look for sparks and dimming
when wiggling the fuse.
kennethowens is offline   Reply With Quote
Old 10-14-2009, 08:25 AM   #7
G.H. , Michigan
I am plugged into shore power so I assume I should be looking at the converter. Thanks for the ideas and yes GH is Grand haven.
Old 10-14-2009, 08:35 PM   #8
Minno's Avatar
Originally Posted by sbroemer View Post
... yes GH is Grand haven.
Cool! I grew up in Grand Haven, and Kay is from Spring Lake! After my 6 year tour in the Navy, we ended up settling in Minneapolis because that's where I found a decent job. We still have family in Spring Lake and Grand Rapids, and make at least two trips there every year.
Chris
Very hot 12v light fixtures modarch Lights - Interior & Exterior 9 05-14-2009 07:33 AM
My 12V lights were pulsing vhord Batteries, Univolts, Converters & Inverters 4 07-09-2008 02:25 PM
New lights and the 12V issue soldiermedic Electrical - Systems, Generators, Batteries & Solar 8 10-30-2006 07:33 PM
My Furnace Won't Blow AirSpleen Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-07-2006 09:04 PM
lights 12v and 110 v moe146 Electrical - Systems, Generators, Batteries & Solar 5 05-16-2004 07:37 AM
