Old 11-20-2014, 12:15 PM   #1
1969 23' Safari
fairfield , Pennsylvania
furnace 1969 Safari
I have looked at instructions on how to light the furnance it is the original. I still dont get it. I was advised that I should not try to light it due to its age. Can I get some feedback on this I use a small space heater that works just fine, but I would like to use the onboard heater if possible.
russellsue is offline   Reply With Quote
Old 11-20-2014, 01:00 PM   #2
2007 22' International CCD
The issue is that an older furnace may have a crack or corrosion in the heat exchanger. The heat exchanger separates the flame from the air flowing over the heat exchanger. If there is a crack or other opening in this part, carbon monoxide can get into the heated air that goes into where you are living.
Carbon monoxide is colorless, odorless, and can build up in your blood. It does not come out of your blood cells easily, and if it builds up enough will kill you, period. Not a good way to die.
The heater, if it is original, could have cracked heat exchanger metal in it, and is therefore dangerous to use. You are getting good advice.
Consider replacing the heater with a new one. Your life is not worth trying to use a possibly dangerous heater. You should also have a battery powered carbon monoxide detector permanently installed in your AS as well as a smoke detector for your safety.
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1969 Safari Furnace won't light. Protosport Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-11-2008 09:11 AM
Furnace for 1969 Tradewind suzwoodard Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-31-2005 10:10 AM
