Old 01-06-2003, 06:16 PM   #1
Catalytic Heater
catalytic heater.
I bought a 1963 Tradewide. One of the discoveries is a LP catalytic heater. It looks good, everything is clean and shiny. I do not know the risk of CO gas poisoning. What is your
opinion.
eracism is offline   Reply With Quote
Old 01-06-2003, 07:15 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
All catalytic heaters burn oxygen, so they must be vented. Some are vented with a small fan. I would assume by it's age yours is not.
So IF it lights and gives off heat you need to leave a vent or window open a crack to allow for the buildup of bad gasses to escape. These heaters were not designed to keep the coach toasty warm, they are for when you need heat and do not want to use 12 VDC power. Or if you are trying to take the "Chill" off the coach they work well. I know many members have them and use them regularly.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Olympian Catalytic Heater davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-19-2022 03:28 PM
catalytic heater norbert Stoves, Ovens & Microwaves 7 10-18-2006 04:09 PM
Auxiliary catalytic heater bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-16-2006 03:41 PM
OLYMPIAN Catalytic Heater JD85EXCELLA32 Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-20-2003 10:21 PM
