Old 07-09-2011, 04:43 PM   #1
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
AC Vibration
So we turned the AC on today and it sounded and felt as though it was going to vibrate right off the roof. It is 6 years old and has always run like a charm. I checked the breaker to be sure it had power and that was good. Quick look at the roof showed nothing through the cowling. Anyone out
there ever had this happen?
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 07-09-2011, 05:03 PM   #2
Wabbiteer's Avatar
Jupiter , Florida
They call them squirrel cage fans for a reason?
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 07-09-2011, 06:42 PM   #3
Willoughby , Ohio
Haha!
Steve & Susan
WBCCI# 03876
AIR# 6511
Old 07-09-2011, 07:18 PM   #4
Goal15's Avatar
Holly Lake Ranch , Texas
When we were on vacation a couple of weeks ago, if I sat on the left hand side of our front couch, it felt like i could feel a vibration from someplace, could have been the AC but it seemed to be working okay.... not sure but perhaps i didn't have the stabilizer jack properly engaged on that corner. but it kind of felt like a little tiny earthquake feeling.
Goal15 is offline   Reply With Quote
Old 07-09-2011, 07:37 PM   #5
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Mud dobber nests
I had mud dobbers nest on the underside of the fan blade on the roof side...made quite the racket...
mopariac is offline   Reply With Quote
Old 07-09-2011, 07:59 PM   #6
Willoughby , Ohio
Maybe tomorrow I'll climb on the roof and take the AC cowling off to see what I can find
Steve & Susan
WBCCI# 03876
AIR# 6511
Old 07-09-2011, 08:32 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I'd go with the Mud Dauber check. A good hose will clear that.
Old 07-10-2011, 06:15 AM   #8
Willoughby , Ohio
The culprit (s)
Steve & Susan
WBCCI# 03876
AIR# 6511
Old 07-10-2011, 09:41 AM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Usually after you remove the petrified mouse from the blower the vibration stops
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-10-2011, 01:42 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Mud daubers did the same thing to my squirrel cage. I took the AC cover off, cleaned dirt from all areas and then prayed everything with water. I run the AC off my Yamaha generator once a month to exercise the gen as well as throw off any new mud dauber nests they might try to build. So far no problems for several years.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-10-2011, 07:04 PM   #11
Willoughby , Ohio
Great tip - we'll run it every month to be sure - thanks!
Steve & Susan
WBCCI# 03876
AIR# 6511
Old 07-10-2011, 08:04 PM   #12
davidz71's Avatar
1986 25' Sovereign
That should have been SPRAYED, not prayed! Of course, I pray I don't have to go through that again anytime soon.
Craig
AIR #0078
3.73 rear end
Old 07-10-2011, 09:17 PM   #13
Central , Mississippi
Originally Posted by Steve & Susan View Post
The culprit (s)
I've had the same problem...and it's soo much fun to clean up the mess in the sun and heat...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Digging My Own Grave; Or, If I Could Only Take it Back! Dumpster 1970 - 1973 Overlander 296 02-25-2016 07:31 AM
Rear A/C wiring in! texascanuk Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-29-2011 04:29 AM
How much vibration is normal? jeffwink Wheels, Hubs & Bearings 8 06-28-2011 08:49 PM
2 questions about lcd installation. Speakers and vibration mikeandnora Audio, Video & TV 5 05-04-2011 07:08 AM
GearVendor Vs. MileMarker Buttercup Mechanics Corner - Engines, Transmission & More... 25 01-04-2011 08:00 PM
