Old 08-17-2015, 12:25 PM   #1
grumpys's Avatar
2014 Interstate Ext. Coach
Grove City , Pennsylvania
AC fault problem
Yesterday we were at a family members house and was using one of their outlets for power. After we had the AC running we tripped the circuit breaker. I looked at the AC control panel and it showed a E7 fault. I turned off the AC and when we got home I plugged into our power outlet. Now I try to turn the AC on an all I get is a blank screen. At a loss can any one help?
grumpys is offline   Reply With Quote
Old 08-17-2015, 03:15 PM   #2
Rich W's Avatar
I'm In , Kentucky
You need a 30 amp service plug to run your AC. Were you using a 30 to 15 amp converter (dog bone) to plug into a regular outlet?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 08-17-2015, 03:42 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Is the 20 amp air conditioner breaker in the trailer tripped?
I found this on another site also,
"Do this.............turn it OFF. Then HOLD DOWN BOTH the zone and mode buttons AND while you are holding them BOTH down you turn it back on. "FF" should appear on the control and then you let up BOTH buttons and it should work again."
Old 08-17-2015, 03:45 PM   #4
Naples , Florida
That is the re-set for the t/stat, but only works that way with the Dometic CCC-1 model. The newer CCC-II will display 'init' in the window and then the zones when turned on again.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
ac fault problem grumpys General Repair Forum 0 08-17-2015 12:25 PM
Fault showing on my CO detector? Minnie's Mate LP Gas, Piping, Tanks & Regulators 15 12-13-2006 12:59 PM
LP gas detector fault mode silverback Electrical - Systems, Generators, Batteries & Solar 6 02-15-2005 06:42 PM
It's all Stef's fault... wahoonc Repairing/Replacing Floor &/or Frame 19 12-28-2004 10:01 AM
Power Steering Fault. canny_banjo_man Mechanics Corner - Engines, Transmission & More... 2 05-09-2004 12:17 AM
