Old 05-26-2005, 10:24 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
AC/Drain pan problem
I have an 84 310 Limited Motor home. The two roof air conditioners seem to function fine. Unfortunately there were leaks between the drain pan and the roof. A fellow who was working on the MH tried to remove the ACs to re-seal them but he drain pans had been attached to the roof with an adhesive which had hardened and the pans were destroyed in the process of removal. So, I have functional coleman ACs but no drain pans. The local Airstream dealer and Inland RV says the drain pans are NLA.
Any suggestion?
Anyone know of a source for the pans? Or, specs for the pans so that I could fabricate them or have them fabricated?
guy99 is offline   Reply With Quote
Old 05-27-2005, 07:03 AM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
"btdt" not much you can do . i looked for the pans also for a couple of years .
as andy stated nla . i finally replaced my colemans with dometic penquins. those pans are available. the colemans were fried by virginia power.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 05-27-2005, 08:42 AM   #3
guy99's Avatar
Images: 16
Bummer. Anybody got a picture of one of these pan? Dimensions?
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
