A trip to a service center is probably in order....
Do you hear the compressor running? Set it to fan only and see if it gets quieter. But either way, I suspect you are going to need service. If the compressor is running, you may have a refrigerant leak. If it is not, the leak may be old enough or bad enough that the low pressure switch is keeping the compressor off or the expansion valve is plugged and the high pressure switch is. Check your filters. It is amazing to me how quickly ours get stopped up. If you can see the evaporator fins when you pull the filters see if they are cold.
