Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 10-14-2008, 09:58 AM   #1
1976 31' Sovereign
Dallas , Texas
Refrigerator & stove suggestions
We have a 76 airstream witht he original regrigerator and oven.
Fridge is going out and the oven needs to be replaced. What do y'all recommend to look at as well as stay away from in thinking about these items?
RonP is offline   Reply With Quote
Old 10-14-2008, 10:36 AM   #2
Moderator Emeritus
overlander64's Avatar
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings RonP!
Welcome of the Forums!
Almost ten years ago, I had a new Dometic Americana 3-Way refrigerator installed in my Overlander. This refrigerator has been a marvel of reliability and dependability. I always travel with the LP off, so the 12-volt mode has seen plenty of use and it reliably maintains the same temperature as the LP mode. My installer did have to run a heavy supply line from the 12-volt distribution panel. Given my experience with the Overlander, I have no question about which refrigerator will be going into my Minuet when its original Dometic refrigerator fails -- it will be a Dometic Americana 3-Way unit.
Dometic Americana Refrigerators
I have been very fortunate with the ranges in my coaches. The original ranges in the Overlander and Minuet continue to perform flawlessly so I haven't had to approach the question of range replacement.
Good luck with your projects!
Kevin
Kevin D. Allen
AIR #827
1964 Overlander International
Road Trip, Tips & Suggestions welcome! JimHoek On The Road... 6 10-16-2007 09:15 AM
Restoration of 1968 Caravelle - Appreciate Any & All Suggestions, etc merlin Member Introductions 4 05-03-2007 08:05 AM
Building L sofa Need Help & Suggestions (Bob Villa) LI Pets Cabinets, Counter Tops & Furnishings 21 11-08-2006 11:22 PM
55 FC DAVIS combination stove & refer fly2havefun Stoves, Ovens & Microwaves 1 10-15-2006 09:08 PM
Stove jeanarlene Stoves, Ovens & Microwaves 25 08-27-2004 08:39 PM
