Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 02-10-2004, 10:29 AM   #1
Profile:
Cook Top Range
I wish to place an order for a cook top. Found a good source for a Suburban cook top, but wish to see if Maytag makes a SS unit that burns propane. The Maytag home page does not show SS nor propane.
Does anyone have a source for a Maytag?
Dick
Navigator is offline   Reply With Quote
Old 02-10-2004, 10:36 AM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Not a Maytag, but Kitchenaide makes a 2 burner that is LP or natural gas. I have one in my MH that I installed.
Most Natural gas appliances can be fitted to work with propane by the installation of the proper orifices or a pre appliance regulator (that is what mine has). You would need to contact an appliance installer or gas guy regarding the regulator. Many manufacturers offer the orifice kits as a separate part for those that are going to use LP.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 02-10-2004, 12:39 PM   #3
Profile:
Brett,
Kitchenaid, now why did I not think of that? Are you happy with that unit?And Karma to you sir.
Dick
Old 02-10-2004, 12:45 PM   #4
Just a member
Images: 21
I LOVE IT.
With shore power I have electronic ignition, Since it is only 2 burners I gained almost 50% of the counter top that the old one took up and it has sealed burners so when I boil stuff over I have an easy cleanup.
Just as a point of reference we full timed in a 31 foot Airstream trailer for almost 3 years with a regular Magic Chef cooktop/stove. I never used more than 2 burners at one time. One of the Kitchenaid ones just ended on ebay for 289.00. Most places will hit you for 400 NIB.
Brett G
Old 02-10-2004, 03:41 PM   #5
Profile:
Among the things which absolutely baffle me is the continued insistence of the RV industry to inflict those large three burner cooktops on us. WIth counter space at such a premium, it is simply inexplicable.
I do a lot of cooking, and even at home I almost never use more than two burners, so I too pulled out the monster oven/range and installed a two burner cooktop. The additional space has made a huge difference in the livability of our coach.
I don't know if it is stll there, but last time I was over at Colaw's RV salvage they had a brand new Seaward Princess two burner cooktop at the very attractive price of - well, I forget. $150 or so. See http://www.colawrvsalvage.com.
Mark
Old 02-10-2004, 04:10 PM   #6
Just a member
Images: 21
Mark,
I can tell you why in one word
CHEAP!
The three and 4 burner cook tops that are installed for RV use cost no where near as much as the 2 burner seaward and kitchenaid tops. I have a Motorhome magazine that Chris for England sent me, you should see what they have. There cook tops are 2 and 3 burner, but if you did not know where they were you would have a time finding them they are so built in. I really miss my cook top on our 74. It was a 4 burner, but with the cover closed it was all counter space. The unit was flush mounted into the counter. Then the waste of 4 burners was not an issue since I could cover them and use the space effectively.
Brett G
Old 02-10-2004, 05:49 PM   #7
Profile:
Certainly a Seaward cooktop is expensive, but Wedgewood makes a two burner cooktop for RVs, and so do some others. They are available, but you seldom see them.
My problem with the folding top is that the time I need counter space is precisely when I am using the range! Sure the folding top helps, but I need some counter top in addition.
By the way, I should have restricted my comments to smaller units. I can certainly understand a full size range and oven in a 30' coach.
Old 02-10-2004, 07:18 PM   #8
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
How about this one?
https://www.rvpartsoutlet.com/newsto...EA1291C6E25D59
Uwe
www.area63productions.com
Old 02-10-2004, 08:29 PM   #9
Profile:
That is very similar to mine, but I do think mine is a Wedgewood. I found mine at Colaws RV salvage with a steel pan that is made to recess into the counter top so that the burners are at or maybe just below counter level. This allows a cover to fit over the unit which is almost flush with the counter. I was told they were surplus from Allegro motorhomes.
If interested, you may be able to make it out in the "kitchen" photos - click on the "Photos" button below.
Mark
Old 02-11-2004, 06:36 AM   #10
Profile:
J54Mark
Wow! what a beautiful interior.
Yes, that is the effect we would like to create.
Trashed the old 4 burner oven and would like to find an upscale cook-top.
Dick
Old 02-11-2004, 06:41 AM   #11
Profile:
Uwe,
Thanks for the lead!
Dick
Old 02-15-2004, 02:02 PM   #12
markus's Avatar
Profile:
Ok.. after the race then
I am refurbishing my 4 burner cook top.
Its a Magic Chef made by "Gaffers & Sattler inc"
I can only make out the first 3 digets on the tag{fryed to a crisp}
"T222. There are some other numbers after, but , 4getit.
the online parts places can't help w/out a #.
73 soveringn int 31'
How bout cha 31 intl??
thanks in advance [after the race]
~markus~
markus is offline   Reply With Quote
Old 02-15-2004, 02:57 PM   #13
Profile:
Marcus,
We have identical toys.
Dick
Old 02-15-2004, 03:18 PM   #14
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Exclamation
Marcus,
Let me know what you find in the way of parts. I need to rebuild mine too, but I have a different set of model numbers BT 843S 4ST Don't know if those will help or not. Mine is a 1975 with a build date of 5-29-75
Aaron
WBCCI #2449 AIR #2495
