The cycle on a propane refrigerator is very long. The flame stays on for a fairly long time each time it is ignited. Sometimes it takes several "clicks" (sparks) to re light a burner which is off, especially if it is dirty. I had one which would soot up now and then, and when it did that, it had a hard time lighting and would do what you mention yours does. So, not a disaster, or super critical, but I would either clean the burner yourself if you can or are willing to try, or have a shop do the job for you.
The problem will probably get worse as time goes on if nothing is done, and then one day it will not light at all, and your refrigerator will not cool (always when you are far from home on the hottest day of the year).
