Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-06-2010, 09:20 AM   #1
2008 23' Safari FB SE
Boulder , Colorado
DPDT Switch Depth - where did you find one deep enough?
I am doing the 2 fan upgrade on my refrigerator replacing the noisy factory fan with 2 SilenX 46CFM fans.
I wanted to install a DPDT switch to control the fans but after looking at the available switches at home depot/radio shack, it appears that none of the switches have enough depth to them to span the width of the particleboard that surrounds my fridge on the '08 23FB. (This is the particleboard that is covered with the thin wood veneer.)
I wanted to install the switch inside the closet to the right of my refrigerator so we could control the fans from insdie the unit instead of having to go out to the outside.
Has anyone successfully found a DPDT or regular toggle switch that would span that gap and allow the thread that seats the toggle to be threaded down to fit the width of the particleboard? If so, where did you buy it?
I ideally would like to find a switch that is illuminated so I know when it is on versus off.
Thanks!
bonginator is offline   Reply With Quote
Old 09-06-2010, 09:59 AM   #2
Naples , Florida
Try here: http://order.waytekwire.com/scategor...itch/Switches/ and look at the Carling brand switches. They are rocker type and come in different configurations, including DPDT and illuminated.
lewster
Old 09-06-2010, 10:09 AM   #3
Ag&Au's Avatar
Port Orchard , Washington
Thanks!
Have you looked at J B Saunders in Boulder? I haven't been there for a few years, but they have a lot of stuff.
I am curious why you need DPDT. Do you want to switch back and forth between the old and new fans?
Regards,
Ken
Ag&Au is offline   Reply With Quote
Old 09-06-2010, 10:19 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I looked through Grainger's DPDT switches and you may have to go with a rocker style switch rather than a toggle. You will have to make a rectangular cut out. I have not seen a toggle with a long enough treaded section to work.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is offline   Reply With Quote
Old 09-06-2010, 05:06 PM   #5
Boulder , Colorado
Regards,
Ken
I'd like to be able to turn one fan or both to control airflow. Thanks for the tips so far!
Old 09-08-2010, 05:49 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
I've never seen a toggle switch with a long barrel. There are push on-push off switches with long barrels.
Otherwise, you can counterbore the particle board from the rear to provide clearance. Or, bore a large hole from the front, and mount the switch in sheet metal trim.
Old 09-08-2010, 06:42 AM   #7
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
If I understand what you need there is a requirement to have both fans switched off. If that is the case then you need a DPDT three position switch.(ON-OFF-ON). The Digikey folks have the switch you need and a nice tutorial on switches.
Regards
Bill
DigiKey Corp. | Electronic Components Distributor | United States Home Page
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 09-11-2010, 01:04 PM   #8
Boulder , Colorado
Regards
Bill
This is what I was looking for.
Great drill depth stop SailorSteve General Repair Forum 7 01-24-2009 12:45 AM
outlet box depth tinbender Batteries, Univolts, Converters & Inverters 10 02-27-2008 07:04 PM
In beyond my depth! jking Classic Motorhomes 5 09-01-2006 12:23 PM
Deep cycle battery switch jaiman Classic Motorhomes 3 07-23-2005 01:28 PM
How deep am I getting? jade_stone General Interior Topics 10 09-18-2002 10:04 AM
