Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 01-22-2010, 03:38 PM   #1
1972 31' Sovereign
Edwards , Colorado
Dometic RM 75a... hot/ground reverse
Frige has been working fine until two ago. I'm getting a hot/ground reverse at the outlet when I plug in the unit. The outlet tests correct whenever the fridge is not plugged-in. I have replaced the extension cord from the unit thinking maybe the problem was in the old cord, but no luck. Any ideas would be greatly appreciated.
thanks,
jay
jayhudd is offline   Reply With Quote
Ground wire getting hot????? 86Scotty Batteries, Univolts, Converters & Inverters 45 02-09-2014 04:09 PM
Hot Ground/Neutral Reversed Snaken49 Electrical - Systems, Generators, Batteries & Solar 14 08-23-2009 03:27 PM
Dometic RM 75A - Need burner housing and plate. Zac A Taylor Refrigerators 0 09-02-2008 11:38 PM
62 Dometic Fridge is HOT!! koelbel Refrigerators 9 04-17-2008 07:43 AM
