10-22-2014, 07:50 AM
1954 22' Flying Cloud
1967 24' Tradewind
manerba del garda
, Italy
Watch out for lightning!
Hi all!
...and what about lightning safety? I mean just frequent in summertime wide campground, not only overseas. Living in Italy sometimes I get it next my house, no real problem inside except great noise. I wonder if AS's aluminium structure is a sort of lightning buster! Is there real danger? Or we stay in a sort of Faraday's gate?
Luca
10-22-2014, 08:04 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
It is a suitable Faraday protected shell. We have BIG lightning here in Texas...I stay inside and worry about hail.
10-22-2014, 08:06 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
As long as you're entirely inside you're probably safe, just like with an automobile. Electricity follows EVERY path to ground that's available, with the current inversely proportional to the resistance of each path. A parked trailer is grounded to earth through the tongue jack and stabilizers, and as long as you're not also grounding the trailer to earth with your body…
By the way, within the United States (since you mentioned Italy) the lightning capital is south Florida, with more lightning strikes per year than anywhere else.
10-22-2014, 11:15 AM
1974 Argosy 26
Morrill
, Nebraska
I don't know about others. But I use a wood block under the tongue jack as well as the stabilizers. Not much protection there.
If you are connected to shore power. The trailer is grounded. But the small wire (#6) would likely vaporize with a direct hit.
10-22-2014, 11:20 AM
From All Over
Wet wood is an excellent conductor.
10-22-2014, 11:21 AM
2014 30' FB FC Bunk
Hoover
, Alabama
I thought the "you are safe in a care" business was a myth? Googly time
10-22-2014, 11:24 AM
2014 30' FB FC Bunk
Hoover
, Alabama
Oh never mind - mostly true - but not because the tires
As such perhaps the tongue jack on ground is not a problem?
http://www.weather.com/news/tornado-...s-car-20140625
10-22-2014, 12:36 PM
1972 25' Tradewind
McHenry County
..... If you are connected to shore power. The trailer is grounded. But the small wire (#6) would likely vaporize with a direct hit.
I hardly trust the power posts at the campground to provide decent power let alone an adequate ground.
That being said and old Airstreamer once told me to leave one stabilizer jack down on the dirt for a good ground.
I suspect it was prudent before grounded outlets and GFCIs when a bad circuit could make the skin “tingle”.
Still seems like a good idea though.
Tom
10-22-2014, 10:21 PM
1999 34' Excella
Hillsboro
Grounding .... if we use the little plastic blocks under the stabilizers, then, no... they are bad for 'grounding'...
I went to HD and, in their 'scrap' area found some 3/4'x 1'x4' plywood boards. They cut into 4 fairly equal pieces easily. A 'stack' of them will allow you to 'adjust' to your camping site... more or fewer... easily They are also great for jacking the trailer if you NEED to on side of the road for flat repair...they are also NOT slippery like the little plastic wafers.
The cost of the wood is sufficient you can replace as they become unusable.
Another good choice is 4x4 cut into 1' lengths. You can place them next to each other and 'glue' together with Construction Adhesive. Just clamp to let them cure before use.
You can also from your 'safety chains' onto the ground... any place to give more 'contact' area for the electricity to find it's way to earth..
Peace and Blessings..
Channing
WBCCI# 30676
10-23-2014, 05:40 PM
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton
I usually let my tow chains fall to the ground when I unhitch. It seems that the chains would be as good a ground path as any, maybe better.
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
10-23-2014, 06:15 PM
Biloxi
, Mississippi
After living on sailboats for a number of years and getting direct strikes 3 times I can attest that no matter what precaucations you take if you get hit it will hurt grounded or not. Electronics will fry at the very least. Has anyone got real first person experience with a direct lighting strike in an Airstream? Not Internet myths or rumors.
MICHAEL
10-23-2014, 06:24 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
If the cables going to the computer external stuff are not RF shielded, then they serve as an antenna for the RF signals in the lightening with disastrous results. I had unshielded four conductor wires going out to terminals (RS-232 serial cables) like VT-100s and when the office building looked like an ice cream cone with the white lightening sheet covering it, all kinds of things died (not on the power cords though)
10-23-2014, 07:14 PM
Northeastern
, Kentucky
I'd be curious to hear Andy's thoughts on this issue?
10-23-2014, 07:44 PM
1999 30' Excella 1000
small town
, Maryland
I don't think it would be a good idea taking a shower during a electrical storm.
10-23-2014, 09:17 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
The aluminum shell is going to do a great job of carrying a lightning bolt around the interior of the trailer to ground.... Unless it is hit with a mega huge lightning bolt, a huge bolt is going to go where it wants.
10-23-2014, 09:32 PM
Airstream - Other
Bosque Farms
, New Mexico
Our Airstream took a hit in the summer of 2012 while I was in Santa Fe. One wild night, that was! Suffered no damage to the "electronics," such as it is in a 1967 rig. There are a couple of small spots in the aluminum in the back that kind of look like somebody touched a welding rod to the skin very briefly. (My neighbor's newer, SOB rig wasn't hit directly, but it did take a major hit to all of its electronics.)
Interestingly, the same storm also struck here in Angel Fire, and we took a hit to our park-wide wifi antenna. It knocked a hole into the side of the antenna itself and literally exploded the power supplies for the associated electronic equipment inside the building; of course, all of the equipment was also toast, not just the power supplies. (We now have an antenna that can be reversed to point downwards during lightning storms.)
Lynn
ACI Big Red Number 21043
10-24-2014, 07:58 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Wooden and plastic grounding blocks should always be green (all the EEs are laughing).
10-24-2014, 08:04 AM
King of the Zebra Speedo
Obrien
Green is ground the world around...
-Red, waxing poetic...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
10-24-2014, 08:08 AM
1967 24' Tradewind
manerba del garda
, Italy
Good advices about a question found already out in the past, similar threads. However thought seems to be a slight concern in our mind. I never really get notice about trailers' outbreak for lightning...so I think for some reason it's very very improbable to happen. In this case I guess building up a hard grounding plus lightning rod could transform our trailers in a sort of Adams' family house!
Luca
10-24-2014, 08:10 AM
Obrien
Great! Now I've got to redecorate my trailer with an Adam's family motif...
-Red, wondering why he didn't think of this sooner...
