Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 04-07-2019, 11:38 AM   #1
Martinez , California
Turn off the pump while traveling
After many years of religiously turning the pump off while traveling, it finally paid off, sort of. While driving on the horrible California highway I-5 the roll of paper towels fell (bounced) off and hit the kitchen faucet handle. No problem until we go in to use the restroom, turn on the pump and the water starts flowing onto the kitchen counter. Now in addition to turning off the pump I will stow the paper towels while traveling.
klstraka is offline   Reply With Quote
Old 04-07-2019, 11:57 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
We just place a hair tie around the faucet that just sits there all the time. When we travel, we just stretch the hair tie around the handle.
Unfortunately we learned the same way and turned the pump on only to find water running everywhere in the kitchen.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-07-2019, 12:37 PM   #3
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
yup us too. Left pump on and a valve was left on a little. Boondocking found water tank dry and we were miles from nearest water bid. We turn off pump when ever we are using water now. Traveling or not.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 04-07-2019, 08:04 PM   #4
Sioux Falls , South Dakota
"We turn off pump when ever we are using water now. Traveling or not." That's our practice, too. If you are boondocking, the pump will come on eventually, wearing down the battery. If you have an animal inside, and a faucet gets bumped, you could find a flood, or just an empty water tank (and full grey tank). More than one person has left the pump on, gone out for the day, and come back to a flooded coach.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 04-07-2019, 09:34 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I am paranoid..I usually also cut off city water if hooked up when we leave the trailer.
CRH is offline   Reply With Quote
Old 04-07-2019, 09:39 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Had a pipe come apart behind the kitchen drawers once. Glad it happened at home. Had a reason to get rid of that Parkey flooring in the kitchen then. I always try to leave the pump off....
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 04-07-2019, 11:11 PM   #7
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
I hear you regarding the lovely I-5. Sadly, 101 and 99 are no better. Went to Palm Desert a few weeks ago via 101 going and 99 on return to avoid 5 and still shook stuff loose that shouldn't. Our high CA road use taxes at work.
StuartsDad is offline   Reply With Quote
Old 04-08-2019, 12:34 AM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, and that is one reason that I added a red LED light on the control panel so I could tell if the water pump was on or off.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline   Reply With Quote
Old 04-08-2019, 12:52 AM   #9
Sag Harbor , New York
That is not paranoia . . . but rather good ol' standard practice. Turning the city water off when you sleep is also a good idea IMO. Fittings can let go in the middle of the night, and flood the trailer.
Don't ask how I know . . .
Old 04-08-2019, 06:59 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We, also, have had issues with the kitchen faucet vibrating open while underway. We always try to make sure that the pump is off before getting underway. We also turn off the city water supply at a campground when we leave the airstream. this prevents a small waterline leak from becoming a disaster.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 04-08-2019, 08:11 AM   #11
Mollysdad's Avatar
I see no reason to leave the pump on unless I'm using water.
Mollysdad is offline   Reply With Quote
Old 04-08-2019, 09:36 AM   #12
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I agree with Mollysdad I only use the pump when I need water otherwise it is always in the off position.
urnmor is offline   Reply With Quote
Old 04-08-2019, 09:41 AM   #13
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Same here. If it isn't serving a purpose then why have it on!
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-08-2019, 10:24 AM   #14
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Glad to hear I am not the only psycho who does this too.
Fun how we all learn from similar incidents.
Good thing it is only water, left wash the floor. Gives the wife something to do.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 04-08-2019, 10:24 AM   #15
Nomad518's Avatar
2001 25' Safari
Ridgefield , Washington
When we’re dry camping,and I need water for a drink or to wash my hands, I turn on the pump so it runs until the water lines are pressurized, then I turn it off. I use only the water that comes out of the faucet under pressure and no more. Saves water and develops good habit of always turning off the pump when it’s not in use. Pump is always off when traveling.
Nomad518 is offline   Reply With Quote
Old 04-08-2019, 10:39 AM   #16
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Same as others we always turn off the pump while traveling after experiencing the kitchen faucet turning on while underway. Occasionally, I will notice the handle is up when getting to our destination and am happy that we remembered to turn the pump off before we left.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-08-2019, 11:43 AM   #17
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
No reason to leave the water system pressurized while moving down the road ...
mefly2 is offline   Reply With Quote
Old 04-08-2019, 12:02 PM   #18
2017 27' International
Antes Fort , Pennsylvania
Even worse flooding twice from the toilet. Once some paper wedged open the flusher gizmo. I caught that one early. Another time I watched mucho water flowing into the galley from the bathroom. This time the gizmo got stuck by it'self. The moral is after using your toilet make sure the toilet gizmo is not stuck.
alphamale49 is offline   Reply With Quote
Old 04-08-2019, 04:04 PM   #19
Dan and Lynda
2012 28' International
Bremerton , Washington
Us too. We always turn the pump off when we are not using it.
The Cralls is offline   Reply With Quote
Old 04-09-2019, 04:58 PM   #20
2017 25' Flying Cloud
Burleson , Texas
Yep; always try to remember to turn it off and
we relieve the pressure by letting the water run a bit.
That hair-tie idea is great. Gonna implement that.
Traveling Doodah
Mappity map
rodo is offline   Reply With Quote
« Nova Scotia | Top | Congres »
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Turn off roof top Winegard X1 satellite while sleeping NatandGregg Computers, Internet & Satellite 1 12-27-2017 05:03 AM
Turn off propane while travelling? Belbein On The Road... 27 04-28-2014 11:24 AM
Shurflow pump does not turn off tim198 Fresh Water Systems 9 08-04-2013 05:04 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
