Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 09-21-2004, 12:58 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Lost wheel
Just recerved an email from the unit President that our unit Treasurer lost a wheel from his nearly-new 31' Limited near Tyler, Texas. It apparently did appreciable damage to the side of the trailer. No one was hurt.
No news yet of exactly what the failure was; it could have been a broken wheek, a broken spindle or a bearing failure for all I know. The trailer, while new this spring, has quite a few miles on it including trips from Texas to New Mexico, Region 9 rally, the Airstream factory, and a caravan across the Michigan UP.
I'll post more details as available.
John W. Irwin
WBCCI #9632
Old 09-21-2004, 02:09 PM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Shame to hear this but here is a peice of advice for anytbody that reads this.
Aluminum wheels should ALWAYS be checked in the first 100 miles if removed for any reason. If the lugs turn at 100 mile check then check them again after another 100 miles.
New rims sometimes seat to the hub. If putting new rims on anything that had a different rim on it the mating surface should be sanded to remove any rust to make sure the seats flat or you risk loss of wheel.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-21-2004, 07:43 PM   #3
WayWard Wind's Avatar
2004 25' Safari
Loss wheel
Yipes!! A scary thing to happen. Glad to hear there were no injuries. Just a thought---was there grease in the wheel bearings?--- Just a thought.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 09-22-2004, 03:26 PM   #4
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
When replacing wheels torque your lug nuts to the value given for your rig. Most run around 80-90 ft/lbs. Re-torque after 50-100 miles of driving. Over torqueing is just as bad as under torque as it can damage and cause catostophic failure in alloy wheels.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 09-22-2004, 09:21 PM   #5
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
Thumbs up
I know of 3 people in our unit, including myself, that carry a torque wrench for just that reason.
RivetED is offline   Reply With Quote
**Broken Wheel Well** Silvertwinky Wheel Wells 8 05-26-2006 02:57 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
Wheel stud removal? TomW Axles 13 07-28-2004 04:42 PM
Wheel lockup erstrong Brakes & Brake Controllers 2 10-07-2003 12:52 AM
