I would be surprised if you did not have an 1000W Inverter, unless someone took it out?
There are separate plugs with little blue tags which are located by the TV outlet and under the table, I believe? Anyway, what you want to watch out for is running too many appliances on your batteries without being able to recharge your batteries...the TV's are not an issue typically, but a coffee pot, hairdryer, or micro-wave could drain you quickly. Many of us have solar recharge capabilities for charging the batteries during camping; many folks also have nice extra size batteries with their solar set ups to run everything including AC; many folks also use generators to do all the above. Several threads on the forum sharing the knowledge.
