Originally Posted by dickschaak
I just bought a 2014 28ft International signature. I cannot get cable tv to work. If I run the cable inside to the tv I get it. I read that if you are going to use Direct TV you remove a juMper cable and then replace the jumper. I suspect the prior owner used direct tv but did not replace the jumper. However I cannot find the terminals where the jumper is supposed to be. Can anyone help?
Another member posted this (Gary) Hope he doesn't mind me quoting what he said, which worked for me.
"you will need a switch as mentioned. Set the Sat Receiver on the shelf above the BluRay. Hook up the Coax. Now the fun part.
Until you get another switch simply unplug the HDMI cable from the BluRay and plug it into the Sat RX. You won't be able to use the BluRay but both TV's will see the Sat RX as there is already a splitter someplace in the cabinet (current BluRay out to Split In and then 2 Split outs, 1 to each TV).
HDMI splitters from Amazon are pretty cheap. Usually less than $50. What you want to get is a input splitter. 2 or more inputs to one output. Hookup would be BluRay to Input 1, Sat RX to Input 2, Output the same HDMI cable that was into the original BluRay. You will usually need to get a couple of additional HDMI cables. They don't need to be very long.
Mine was a 3 input. On the third input I put a longer 6 ft HDMI cable so I could use my iPad to drive movies.
Lastly you can get a multi input/output splitter that will allow you to watch a different input on each TV. So one on BluRay and one on the Sat Rx. Larger box and usually has a remote control so that you can make input/output selections."
