Go Back   Airstream Forums > Airstream Knowledgebase > Vintage Kin
Old 09-24-2013, 08:30 AM   #1
Smokeydog's Avatar
Gonzalez , Florida
New antenna
Has anyone replaced the original antenna from the 70's with a new HDTV antenna? If so what about new coaxial cable? Does a new HDTV antenna work with the old brown flar cable? Thanks for your thoughts.
Rusty
1978 28.5 model M. Avion
Smokeydog is offline   Reply With Quote
Old 09-24-2013, 08:47 AM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I installed a new Jack HDTV antenna (while all of my internal skins are out). And I will be running new shielded cable as well. I guess that doesn't really answer the question of whether it would work with the old cable....but I think it is of benefit to upgrade to a higher quality shielded cable, when possible.
arktos55343 is offline   Reply With Quote
Old 09-24-2013, 08:53 AM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I think it would be worth it to spend the time snaking in the new line.
Not all those who wonder are lost.
Silverflames is offline   Reply With Quote
Old 09-27-2013, 12:03 AM   #4
Portland , Oregon
Antennas are the same. Our new TV antenna is the same as my dads 40 year old antenna.
Coax cable hasn't changed either. What had changed is the signal strength. You might need an signal amplifier.
Ian Lomax
1966 Streamline Countess 26'
JeweloJalopy is offline   Reply With Quote
Old 09-27-2013, 05:43 AM   #5
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Oh but the cables have changed. It may not be much but the shielding has improved. Less chance of a ghost image. Ghost imaging occurs when the antenna picks up the over the air waves and the same wave gets in through another route. This other route could be a older cable (less shielding) or an open connector (the unused jack that you don't have a tv hooked up to). There is a cap for the unused jacks.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 09-27-2013, 08:09 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Rusty
IN answer to your question. No, a new antenna will not work with a flat brown cable.
Ahab is offline   Reply With Quote
Old 09-27-2013, 08:57 AM   #7
1974 Argosy 20
Kooskia , Idaho
One of the great advantages of digital TV transmission is that there are no longer any Ghosts as there were in analog TV systems. Ghosts were caused by a delayed signal and digital systems do not respond to them.
