Go Back   Airstream Forums > Airstream Knowledgebase > Vintage Kin
Old 08-14-2018, 11:53 AM   #1
Help with 69 Avion
Hi all,
I just purchased this 1969 Avion 28 ft trailer as a project to restore it. The bottom sheet metal panel has seperated at the front corner from the upper metal shell and I'd like to seal it somehow.
I was thinking of either finding a welder to do the job, but the problem is that the metal is very thin aluminum sheeting.
Or I was thinking of using this RV tape - Eternabond tape - http://a.co/74x9kft - from what I've seen most people use this for sealing leaky roofs, I haven't seen anyone us it for this purpose yet, but it seems similar enough, maybe?
Once it's sealed back into place, the material or method used for fixing it shouldn't be visible unless you go under the vehicle.
Can anyone give me tips or advice on this?
Thanks all!
See attached photos
ID:	319877   Click image for larger version
wolfman23 is offline   Reply With Quote
Old 08-14-2018, 03:48 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Remove the rub rail. Make a patch. Tuck it under the rub rail. Reattach the rub rail.
Make the patch large enough to go 6" or more under the coach.
Old 08-14-2018, 05:20 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Good idea.
Here's another: Call Chuck Cayo at (269) 463-5068, tell him what you have and what you need. He might have or can make the entire piece for you.
Keep us posted on what you do.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
1968 c-11 avion slide in truck camper (avion, cayo) panormc Airstream Classifieds 0 03-26-2017 10:11 AM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
need help with a '71 Avion silvermoon71 Vintage Kin 4 09-29-2008 08:43 PM
Avion Help ? aviontt Vintage Kin 1 08-09-2005 06:22 PM
